Here is the problem-I installed some patio doors on an addition. The sheathing used around here is either polyiso foam or OSB with wrb. This particular addition has OSB with Tyvek. I understand that the wrb should lap over the drip cap that has been flashed with tape to the sheathing. But, I haven't found any flashing tape that sticks very well to OSB (it sticks to the wrb well), so for that reason I taped the top of the doors to the wrb. How concerned should I be about water getting behing the wrb? And if it is a concern, then what detail would you use to remedy the issue? Most everyone around here tapes to the wrb on all sides because it's easier than cutting back the wrb. I do it because I haven't been able to get the flashing tape to stick properly to the OSB and it seems like wasted effort if it'll leak anyway if water gets behind there. This addition will have vinyl siding. I've tried Protecto, Opti-flash, and MFN wraps with no success sticking to OSB. Thanks.
Comment
