Sim, after I posted I downloaded your drawing and had a closer look. I could have responded a bit sooner but had a different idea on how to approach this problem and took the time to make up a graphic.
Interesting … I just posted the same answer to a seemingly different question for a "ski slope" roof over at the BT Forum. Here’s the thread in this forum thread where the math was originally developed:
Shed Rafter into Main Rafter Calculation ... start at Post #6
This is a link to the theory:
Circular Arc tangent to Rafter
Use the formulas or open the Excel worksheet at the top of the page. In the first set of fields enter …
Rafter Triangle Rise = 13.87539
Rafter Triangle Run = 21.23616
Length: Difference in Runs = 12.76384
Radius = 96.57785
Or in the second set of fields enter …
Chord = 36.72229
Radius = 96.57785
To check the above numbers, in the third set of fields enter …
Radius = 96.57784
We now have a radius for the large circle. The difference between my calculated radius and the radius in your drawing is likely due to my using numbers from the pdf which have been rounded off to two decimal places. The sum of the circle radii is:
62.17 + 96.57784 = 158.74784
The center of the large circle from the origin is:
x = 158.74784 sin 33.16° = –86.83172
y = 158.74784 cos 33.16° – 38.17 = 94.72518
Quote:
Originally Posted by sbebuilders
... the radius for the tangent circle is not known.
Just curious but your pdf drawing does show a radius. How did you get it? AutoCAD?
Also, my eyebrow_radius.gif has been edited (a bit more info added) and a screen capture from your eyebrow_test_window.pdf of the same intersections as shown in my diagram has been uploaded.
