Thought I would seperate this bowed baywindow roof framing thread from the Bay Roof to a Point Double Bumpout 45° thread started by Joe Carola. The bowed baywindow can be framed 1000 different ways, but this was my take on it in 1984.
I designed and built a house for a relative in 1984 with this bowed baywindow roof.
The side walls were 33.4†, the overhang was 24â€, the pitch was 8/12 with the side
runs being equal to the front bowed window run. I drew it with equal overhang runs,
but I’m not sure if I stacked it with equal overhang runs. Not even sure that I
stacked it with equal common rafter runs. I just looked at the old set of plans I
drew for the bowed baywibdow and I drew it with a 24 point polygon, because I only
had an 8 point polygon drafting template that I was using. This was before cad drawing
programs were an everyday tool.
This is a sketch (on paper) I drew in 1984 for the 5 sided bowed bay window
with a 24 point polygon for window placement calculations . I entered the
sketch calculations into AutoCAD today and ended up with the same dimensions
and angles as I had on paper.
http://www.sbebuilders.com/rfi/image...ow_sketch.html Larger Image of Bowed Baywindow Sketch
http://www.sbebuilders.com/rfi/autoc...-baywindow.dwg Bowed Baywindow Calculations Sketch in AutoCAD DWG Drawing Format
So, Joe B., Joe C., and Joe F. is there a genric formula for the calculating the roof framing angles without calulating each and every angle and dimension?
Attached images are the bowed window calculations sketch and the plan view of the bowed baywindow roof framing.
Sim
Sim
Comment
