I figured I would start another thread about Bay Roofs since the other thread was such a good one. This one is a simple one, but the only problem that I see ALL THE TIME when guys frame these is that they put the last front wall common on even with the end of the top plate. For example in my drawing I used a 6' front wall and a 2' bump out for the bay making the bay 10' wide with an 1' equal overhang all three sides.
When guys frame it like this, the side walls overhangs smaller than the front wall. If you shift the first common over on each side including the overhang where the fascia points meet 4.97053" out past the 6' front wall making them 6' 9-15/16", that will make the side wall rafters overhang the same. If you keep them on the corner of the 6' front wall, the side wall overhang is 8.485281".
On the left side of the drawing I used 5/12 as the front pitch and it's also the 5/12 pitch for the rafter up against the wall, therefore the small side wall rafter becomes a 30.51° or 7-1/16/12 Pitch.
On the right side of the drawing the front 5/12 common and the wall 5/12 remain the same and the side wall common stays the same 7-1/16/12 because your just shifting everything over and not changing any plan view runs or rises, just the overhang and birdsmouth location.
Comment
