#1
Old 05-04-2006, 08:19 PM
Bill Lacey Bill Lacey is offline
Default Re: Flashing windows with nail fins
WIndows that are covered by a porch roof (4-6 feet out from the house) probably would not need flashing, but it's a risky game to play. There's always the "what if" factor. I sell seven different brands of windows and none of them say anything about self flashing.
EDIT: How the hell did this become the first post? I'm fifth in line.
__________________
Your guy lost. Get over it.
  #2
Old 05-05-2006, 12:51 AM
Lavrans Lavrans is offline
Default Flashing windows with nail fins
I am wondering how others deal with windows with nail fins. It seems that a lot of the manufacturers are backing off their claims that the windows could be considered self-flashing. I have always flashed them regardless of manufacturer claims, but still wonder what you do, and if you rely on the window to self-flash, how have they been doing?
Lav
  #3
Old 05-05-2006, 01:15 AM
Toolwhore Toolwhore is offline
Lav;
There isn't, and never has been, a self flashing window. Read this; JLC, June 2005, Flashing a Flanged Window.
__________________
  #4
Old 05-05-2006, 01:56 AM
Tom- I know there has never been a self flashing window, but, for example, I know some people who think that vinyl windows with nail flanges don't need to be flashed. I may be imagining this, but I'm pretty sure I have read instruction books that claimed flashing wasn't needed under certain conditions. Regardless, like I said, I don't think any should be installed w/o flashing. I am just wondering who doesn't, and how their callbacks have been.
  #5
Old 05-05-2006, 02:21 AM
Vinnie Vinnie is offline
The fins or windows may stop the water from making it to the ground. I think that if we should stop the splash of the water. After that, will not have the water fighting to get in to the homes. So If the windows do not splash than the water can drop away from the window.
  #6
Old 05-07-2006, 01:45 AM
davenorthup davenorthup is online now
Quote:
I am willing no one here does... :) (not flash windows that is) I think Bill R. would come over and smack anyone if they did.
I am re-siding a house that had absolutely no flashing what so ever. Amazingly enough the house is dry except one window. The original builder really screwed these people, and no flashing was a minor issue. This re-side has turned into a big job. Ok with me.
Bill - I hope this will replace you as first post in the weird forum vortex...
  #7
Old 05-07-2006, 02:10 AM
Bill Robinson Bill Robinson is offline
2003 IRC
703.8 Approved corrosion-resistant flashings shall be installed....
1. At top of windows EXCEPT that self flashing windows having a continuous lap of not less than 1 1/8" over the sheathing including corners do not require additional flashing. jamb flashing may be omitted when approved by the building official.
This is in the 2003 IRC.
the 2006 will read differently.
I would hope that you would follow ASTM E 2112 and use 9" wide, 24 hour minimum water resistance continuously labeled flashing.
If you don't, please let me know where you are building so I can do some more consulting for construction defects. Bring your pink slips cause I will be collecting them>;}
Bill R
  #8
Old 05-08-2006, 05:25 PM
Adam Smith Adam Smith is offline
[QUOTE=Lavrans]I am wondering how others deal with windows with nail fins.
Grace Vycor...I hope this isn't a trick question!
__________________
TwoSons Construction
  #9
Old 05-08-2006, 09:13 PM
Finnegan Finnegan is offline
I would flash a window even under a deep overhang. You never know when someone is going to hose down or pressure wash that wall. The flashing should also cut down on air infiltration.
  #10
Old 05-09-2006, 12:42 AM
So, no one here would skip flashing. I haven't worked with anyone who would skip flashing. I can't find anyone who will admit to skipping flashing. So why do I keep running into unflashed windows?
You've got to admit that job security can be a depressing thing.
Lav
  #11
Old 05-09-2006, 07:45 AM
Maybe it's the people who have a good relationship with the inspector, and they are allowed to leave out these "minor details" just to save a buck.
__________________
  #12
Old 05-09-2006, 08:07 AM
Stuccoman Stuccoman is offline
Each window that has trim around it needs three peices of metal z flashing with proper laping of the moisture barriers along with backer rod and sealant on the sides.
www.badstucco.com/properflash/properflash.html
1.Under the nail fin at the bottom under the trim and out over the sideing.
2. At the head of the window out to the sides of the trim not justto the corners of the window.
3. At the top of the trim above the head of the window.
  #13
Old 05-09-2006, 02:02 PM
I have also seen enough unflashed windows. I think the folks who spend time on this site are interested in finding the best construction practices and are probably not likely to do things obviously wrong. However, I am sure that there are enough of others out there willing to cut a corner.
  #14
Old 05-09-2006, 03:58 PM
Sweep8 Sweep8 is offline
Here is post from another site
Quote:
W R Grace products work well for sill and jamb flashing but can be a problem when used to seal the fin-to-frame seam of a clad window because it puts the edge of the asphalt membrane well into the trim-to-frame joint where it can come in contact with the cladding/trim sealant. Many popular modern sealants contain plasticizers that can soften the asphalt, even liquify it so that it drains out of the joint at a lower point.
Butyl (StraightFlash, SmartFlash) would be a better choice if you need to seal the fin on a clad nail-fin window but you should always put some beads of the sealant you want to use on the sticky side of the flashing a week in advance to see if one reacts with the other.
I was taught that butyl should be compressed between two non-pourous (metal or glass) materials but that was before pressure-sensitive adhesive tapes were marketed as permanent seals. It is still true, however, that the non-pourous surfaces must be cleaned with a solvent to remove anything oily, even fingerprints (gloves required).
All self-adhering flashing must be rolled with a small rolling tool, not just to get air out but to insure the initial seal. A little friction to warm the tape can sometines help as well on pourous surfaces. For flexible self-adhering flashings the AAMA sets the minimum overlap of a seam or joint at 2 inches. Unfortunately that is not possible at a nail-fin seam without exposing the flashing.
Here are some of the original references:
http://www.wconline.com/CDA/Archive/...00f932a8c0____
http://www.fortifiber.com/fortifacts...patibility.htm
http://www.aamanet.org/mp/XXX-XX_D2b_4-4-06.pdf
  #15
Old 05-11-2006, 07:35 AM
This is how not to flash windows!
http://www.badstucco.com/ff.htm
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are Off
[IMG] code is Off
HTML code is Off
Forum Jump
2004
