Interesting NAHB Stance
  • Interesting NAHB Stance
    They're suing to maintain the opt-out provision...http://www.qualifiedremodeler.com/on...2113&pageNum=1
    Greg
    Re: Interesting NAHB Stance
    To me it's goofy and just grand standing.
    When NAHB gets into court and the judge ask to see their documentation showing adults are not harmed ... they can't produce any. Because these associations haven't done any test. They haven't done any research. All they will be able to produce is "opinions".
    On a personal note ... I wish the opt-out wasn't gone.
    However wishing it was gone is a far distance from doing my own research/studies and showing it is not needed.
    Dean
      Yeah but it's a good one for bringing in some new money. Times are tough.
      Donald on the basis of his net worth valuation-
      "...feelings, even my own feelings, and that can change rapidly day to day"
        Ah ... was wondering why a new home builder organization would be worried about an old home problem.
        Dean
          NAHB's stance is that the EPA had no supporting evidence or new research to remove the opt-out.
          I'm no banner carrier for the NAHB, but they've been at the table on this issue from the beginning, and a lot of the right concerns and questions were brought up but fell on deaf ears. In the years leading up to the rule's release, NAHB even commissioned their own lead renovation study. There doesn't need to be any new research performed, there's more than enough evidence that the RRP Rule goes beyond what's reasonable to achieve lead safety--and stands to go even farther over the coming years if and when third party clearance testing and expansion to commercial structures come online.
          With the reduction in the market for new construction, NAHB's remodeling wing has taken on greater significance. But again, they were one of the handful of associations involved with the rule from the beginning.
          I've said this before in other forums and it bears repeating:
          There's no question lead safety is important as is the need for educating renovation firms on the issue. But the confusion and resulting bitterness in the industry surrounding the implementation of this rule has done a great disservice to the cause of keeping kids safe.
          Christopher Wright, WrightWorks, LLC
          Indianapolis Remodeling Contractor
          Remodeling Photos
          www.Facebook.com/WrightWorks
          www.Twitter.com/ChrWright
          President, Central Indiana NARI, Named to the 2010 REMODELING Big50
            Many of us would say it goes a bit too far, but as you say it's not a new thing, nor has the industry stepped up to the plate to prevent others from creating regulation, having been too far behind the curve. What is deemed "reasonable" is very mutable and very tied to the flows of money.
              I can tell you if you are a home builder, you should belong to NAHB. It is a great organization that truly doesn't shy away from throwing the gloves down and having a good fight to protect and promote the home building industry, as you can see from the substance of this thread.
              Now I belong to a few organizations, including the AIA, another big one, I can tell you they don't do justice to the architectural profession the way NAHB does it for home builders.
              Join NAHB if you haven't already, what a great organization.
              When you've got them by the balls, their hearts and minds will follow.
              Theodore Roosevelt
                If the opt out comes back which I hope it does look for future mandatory EPA pamphlets with a strong recommendation target groups get tested before and after renovations.
                Lead poisoning by the way is going down not up with state initiatives in the last 10 years. Seems the greater the sample pool, the less percent affected. Seems like it mostly affects sub standard housing and the bums that own them. Locally the rental / apt assoc fought tooth and nail against an initiative to educate and provide far greater availability of testing poor kids. They prevailed. Just give them the HUD pamphlet when they move in and its gets tossed in with the rest of the fed / local paperwork. But the gov't has to come in and label everything a hazard.
                Steve
                "Get three coffins ready" - A Fistful of Dollars 1964
                https://www.youtube.com/watch?v=Wt5ZtBpgBQE
                  A big problem with these studies (NAHB, EPA ...) is they are not a "normal" (average) scenario.
                  Example: Take dust sampling after a Dustless Construction remodel and you will probably find very little to no lead. In fact, the lead dust level will be better than before they started. However, take dust sampling after Illegal Construction and you will have gobs of lead dust all over the place.
                  The differences have to do with the company and the way they do work.
                  Company A may put down tarps ... mist and then use a blade to score the sheet rock, before removing it. Once they finish, they clean up where you can eat off of it. Company B puts no tarps down and uses a hammer to remove the sheetrock. They just use a shop vac to clean up.
                  You will find a major difference in lead levels (dust and air).
                  If I wanted to do a study to show lead is not a problem, I would use Dustless Construction and before hand given special instructions. I would also mention to the owner that I will have his 3 year daughter lick the floor, window sills and counter tops after cleanup (to make sure the area is pristine.
                  If I wanted to do a study to show lead is a problem, I would use Illegal Construction and before hand ... give special instruction (how to make the most dust).
                  In real life (my opinion), there are a ton of contractors who don't leave the area in pristine condition.
                  Dean
                    Depends. In New York, lead poisoning has risen 100% from RRP activities from 1994 to 2007. Happening in other areas too.
                    Generally lead poisoning has dramatically dropped over the decades, but "generally" includes stopping leaded gasoline, checking toys for lead, starting new regulations, controlling commercial lead output and many more items. Just because the general lead poisoning has gone down ... doesn't mean the lead poisoning from RRP activities have dropped any.
                    Dean
                      I'm tempted to say the EPA rule has it all wrong. They want contractors to be trained in safe work habits, and to make owners blameless, but what really should happen is that homes should be tested and lead abated by specialists. Then the average remodeler can go in and work without any hassle at all. I personally have no desire to try to do LSWP and fortunately get most of my work on newer homes. The legal liability alone is enough to deter me. Like Chuck said, "What year was your home built?"
                      Bailer Hill Construction, Inc. - Friday Harbor, WA
                      Website - Facebook
                        Dean,
                        I cant find the graph I was looking for but look at this one. NY / NYC the greater the testing pool, the less % ebl (elevated blood levels)
                        Click on the burgundy graphs on the left
                        http://www.cdc.gov/nceh/lead/data/state/nydata.htm
                        These graphs say in both NY and NYC ebl have been cut in less than half over the last 10 yrs.
                        Addl - Somebody must be doing something right....I wonder what it is ? Whatever it is they should continue to do it. Seems like originally the sampling was done in obvious places with predictable results. Then a greater sampling with out linear results. Now even a greater sampling, the whole country will show now the lowest levels in history in future years. Surely a perverted analysis but will validate the EPA's efforts. Fund the local initiatives. They are working.
                        and....and...and....it will take away resources from the people who need it most, the targeted population, poor kids and mothers. They will literally be left in the (lead) dust while hundreds of inspectors will be out on Forsythia Lane. What else is new ? They can't even get 1 inspector around to sub - standard housing but once every how many years ?
                        Steve
                          Happy,
                          I don't dispute those graphs. In general lead poisoning has gone down. However, if they showed a graph of lead poisoning FROM RRP ACTIVITIES in New York the graph would be heading up ... increasing more than 100% (from CDC website, same as your reference).
                          To use an example: lead poisoning from leaded gasoline has dropped over the decades. This doesn't mean that lead poisoning from RRP activities have dropped.
                          May not be making myself clear
                          Dean
                            I agree Ted, the NAHB is a great organization for builders AND remodelers. There is a tremendous amount of educational and beneficial information available through NAHB, I would encourage all contractors to join.
                            [url=http://twitter.com/Allan_Edwards]Twitter[/url]
                            [url=http://houzz.com/pro/allan]Houzz[/url]
                              Happy,
                              Do you have a link to this data?
                              Remodeling Photos
