Results 1 to 4 of 4
    Roger Nold Guest
    Default maximum span on soffets?
    what are the maximum span lenghths for 5/8 & 1/2 inch drywall? I have a hallway to build soffet in to cover duct work and it is 29 inches wide.
    Myron Ferguson Guest
    Default Re: maximum span on soffets?
    It should be fine to span 29 inches as long as nothing is pushing down on the drywall such as insulation. Go with 5/8 drywall just to be extra safe.
    calvin Guest
    If you could spare a little room you could strap across with hat channel and screw the board to that. The bend in the channel should help support the board on the flat. In high humid conditions you might need the support over time. No saggage. Don't be tempted to screw it to the duct.
    B Kelly Guest
    for best results with kichen soffits I usually frame them with plywood first it's cheap and you can glue and screw over it to get the most out a job that must be plumb and sqaure. sixteen centers on the ceiling and tenty four on the walls with half inch. twenty four on the ceilings and thirty two on the walls with five eighths more for both if backed up with bridging or plywood.
