Ok, not my work, not my responsibility. But...
I am doing seismic work on a 1961 house in the east bay hills. The obviously imperfect (+/- 8'x50') front porch/deck/patio is a concrete slab over 1x sheathing.
There are two cracks running across the 8' dimension that have been allowing water to freely drain through to the crawl below. We are currently in the dry season, but some over-watering of planters above shows damp areas below, complete with mushrooms. Upon examination, there is evidence of repaired rot, and obvious signs of moisture intrusion. The porch will receive rain in the wet season.
There is remarkably little damage to the untreated fir joists, testament to the theory (in California, anyway) that if you don't trap the moisture you can literally let liquid water run through a house. (For some time, anyway, who knows when the cracks developed.)
Again, I am not hired to diagnose or inspect water problems. I am simply the guy in the crawl space doing a seismic retrofit. However, upon seeing this, I had to mention it to the HO.
Short of ripping the entire porch out and starting over, what are your collective thoughts?
Any (even half-assed) ideas about slowing the water intrusion? With the understanding that we are not trying to "fix" it for now? What would you do if it was your house?
Have at it!
kevin
Have at it!
kevin
Comment
