Results 1 to 9 of 9
Thread: Roof Insulation
    Default Roof Insulation
    Hello everyone...
    Currently I am building a small office/studio/gym in northern Florida where it is hot and humid about 8 months out of the year.
    This building has a precise east/west orientation with a shed roof and 2' overhangs on all sides. The roof slopes downward from north to south. I am planning to insulate it with spray foam. The company is saying they'll spray 5" of open cell foam which will be about R19. They also say that is equal to R30 fiberglass. I am concerned about this and would appreciate any thoughts you might have.
    Another question is would I get any benefit from insulating the overhangs? The south overhang will shade the south facing wall throughout the summer months. Some have said the overhang makes no difference, but I'm having trouble believing that if the sun is effectively blocked at the roof level the walls will be cooler if no radiant heat transfers through the overhangs.
    Any thoughts you may have regarding this would be greatly appreciated.
    Thanks,
    elgin
    Default Re: Roof Insulation
    Elgin,
    If you hire an insulation contractor to install R-19, that's all you will get. You certainly won't be getting R-30 (the minimum code requirement).
    This is an old story. Read about it here:
    http://www.greenbuildingadvisor.com/...n-icynene-says
    Houston & Washington Texas
    12,064
    Quote Originally Posted by elgin?s View Post
    In a hot-humid climate homes with 5"-6" of spray foam in rafters and walls will perform much better than R-19 fiberglass in the walls and R-30 fiberglass in attics. I have several new homes built in the last 5-6 years to prove that.
    Twitter
    Houzz
    Jan 2006
    upstate NY
    1,731
    Allan, have you used 5" to 6" of open cell in the ceilings?
    Or did you opt for closed cell?
    Nov 2004
    Boston, MA
    4,738
    They pretty much reject anything less than R38 around her. The honeymoon is over for SPF. Don't matter what material it is, it's got to be R38.
    "First we finish the game, then we’ll deal with the Armada!"
    Sir Frances Drake
    Thank you for all your responses.
    Jan 2006
    upstate NY
    1,731
    I could get away with less than r38 in a lot of localities and have tried it in several. it appears to work good. Have not dared to try the open cell on the ceiling yet. But from what I have read here, it sounds like OC would work as long as the interior is kept less than ridiculously humid(heating zone).
    One thing I am sure of is that the code requirement for insulation values is arbitrary and capricious. So I don't put any stock in the code if I can get away with it. The problem is that there are no unbiased science guys to tell us what a prudent r value would be. So we have to rely on experience. I would put a lot of stock in Allan's examples. But you still never know if another inch would be worth it or not.
    A layman can look at a graph and see that it doesn't take many r's to keep in/out most of the heat/cold. But controlling the surface temperatures takes more r's and there effects on comfort are not as easily understood.
    12,064
    Quote Originally Posted by johnny watt View Post
    We use open cell. Except for wine rooms where we use closed cell.
    Aug 2009
    OrangeCounty California.
    152
    I would like to kow how it is that a company will tell someone that they will install insulation of any kind at R-19 then it somehow magically turns to R-30.
    R value either is a certain value or it is not.
    Andy.
    Was a GC, doing drafting & design now.
    www.draftinginoc.com
Tags for this Thread
