Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Sep 2012
    Greenville, SC
    118
    Default Re: vinyl siding and a leak
    I'm not a leak expert but I am an expert on working on daughter's houses, as I have three daughters and have worked on 5 houses extensively. Infrared, wall cameras, huh ? Just take the siding off and fix the thing. New flashing, reinstall windows, peel & stick, whatever it takes. I would and do want to know that my fixes are the last one that will be done. You already know that the contractor was slipshod. If you find the source of the leak and do a spot repair you may end up doing the same thing next year.
  2. #17
    Des Moines, Iowa
    3,895
    Ablesupe
    Great advice
    That is what we were trying to say but I got lost in the minutia of the discussion
    Mark Parlee
    EDI Seminar Instructor
  3. #18
    fill the gaps with silicone to insulate it properly
  4. #19
    Des Moines, Iowa
    3,895
    Quote Originally Posted by Waiters25 View Post
    Wow this one got past me.
    That's some crazy advice. Absolutely without understanding of the problem or the assembly.
    Mark Parlee
