Results 1 to 9 of 9
    Sep 2009
    Ft Collins, CO
    390
    Default Cantilevered shower bench?
    We are creating a new walk in Master Shower for a client, and they are considering a cantilevered stone (or Tile) bench.
    If we cantilever it, how is it supported?
    Here are the links that she provided.
    Most likely choice for her:
    http://www.houzz.com/photos/59460/_t...om-other-metro
    Not so likely choice:
    http://www.houzz.com/photos/1226046/...-san-francisco
    More like what I am used to doing:
    http://www.houzz.com/photos/89105/_t...-san-francisco
    Apr 2009
    midwestish
    7,536
    Default Re: Cantilevered shower bench?
    Something like this works for example.
    ~ Meriwether Lewis
    Meadow Vista, CA
    2,171
    Ditto what MarkMc said. I use the Better Bench exclusively. I've covered it with tile or with granite slabs.
    Feb 2012
    New York
    804
    Better Bench is the ticket for that cantilever look. Have your stone fabricator make a custom piece and you're done. This one was done with SileStone along with a custom niche. IMG_0699.JPG
    Gary
    Sep 2009
    Portland, Maine
    1,390
    I like the "not so likely" choice the best myself, and it's really easy.
    Giving away secrets....the answer is a simple piece of angle steel (quantity as req'd) bolted to the studs before tile backer and tile. The thickness of the angle is covered by the build-up of the seat.
    Portland Renovations, Inc.
    www.portlandrenovations.com
    We have used both the corner and the rectangular better bench many times since we discovered them.
    You can use the small triangular one as a support under the rectangle on long spans or open ended applications.
    Another thing that we do is put blocking in the walls and use stainless fasteners to attach the bench.
    Apr 2009
    Georgia
    248
    Lettus, I have seen the better bench but never used it. The last couple benches I did, I had my welder buddy get me some 1/4" SS. I have covered my last two benches with a solid surface material (either stone or marble). So I worked out my tile work and set the ss plate down on top of the edge of tile and then covered with with the stone. I did one in my master shower and it has been there 5 years with no problem. I did anchor it to the wall since it is supported by the tiles themselves. Make sense? If not i can shoot u a pic.
    Nate Dizzy you know who izzy
    Mostellerconstructiononline.com
    Sep 2009
    Ft Collins, CO
    390
    Thanks Y'all. My Client is still trying to decide what she wants, but it's good to know about the better bench.
    Chicago, IL
    210
    If the shape they choose does not match with a Better Bench, we just have our stainless guys fabricate the piece we need. WE put a flange or angle at the wall and bolt it in as needed. We try to keep it inside the durock, on top of the water proof membrane, and then waterproof again over the flange.
    Depending on the size and stone you might also get the stone fabricator to set in the required steel and but angles at the wall to support it.
    Never had a problem
