Results 1 to 9 of 9
    Default Help me spec a tub/shower stall
    Upcoming bath project, typical 5x8 bath, customer wants a 5' tub/shower with a window in the 5' wall, probably something like a 3-0 x 1-6 slider, high in the wall. Customer's first shot was to choose a Sterling tub with wall panels, 6-3 total height (too high for a window above IMO) but they don't appear to be the type of thing you can cut into and modify for a window.
    So, I need a quick lesson in tub wall products that allow a custom window. I've done Swanstone before, and of course about a thousand of them with tile walls.
    Anything quick, easy, inexpensive in modular product?
    Jan 2006
    Sarasota, FL
    634
    Default Re: Help me spec a tub/shower stall
    David:
    You may be able to get 1/2" solid surface from Livingstone that would be just the thing for this job although I don't know how well that fits the "inexpensive" criteria.
    It is beautiful, repairable, no grout lines, and won't support mold or mildew.
    Joe
    "I want no heaven for which I must give my reason; no happiness in exchange for my liberty, and no immortality that demands the surrender of my individuality. Better rot in the windowless tomb, to which there is no door but the red mouth of the pallid worm, than wear the jeweled collar of a god."
    Robert G. Ingersoll, "Individuality", 1873
    Feb 2012
    New York
    362
    Solid surface is the way to go but if money is tight that option is out the window.
    Maybe there is an expensive waterproof panel I don't know about?
    Is tile out of the question? Even an inexpensive tile looks better and last longer than those cheesy modular inserts.
    5,578
    Swanstone with the window trim. I've never had a problem with this combo.
    If the window does not exist, how about a short transom made with glass block, you could install vents in the assembly.
    Aug 2012
    638
    You can buy a glass block kit, with the vent included. Use some sort of tile to trim. I've done this a couple of times. It brings in light, vents, and privacy.
    portland, maine
    708
    I don't see why you couldn't cut into the Sterling unit. Use a fine jigsaw blade from the backside. Fill the void with low-expansion spray foam. Make extension jambs and casing out of Azek and caulk it to the surround. Or just use Swanstone or Corian solid panels. Or acrylic panels: http://www.frigodesign.com/sheet-goo...ll-sheets.html.
    Anchorage, Alaska
    713
    What about using Swan's fiberglass product (WW-6000 is just one example)? It's cheaper than the solid surface. They make a window trim kit (WTK-1) from fiberglass to go with the fiberglass surround. Way better than Sterling. I don't think Sterling makes a window trim kit anyway. So there is a way you don't have to use solid surface and can get a nice product.
    6,740
    get them some FRP panels like you see in gas station bathrooms. Cut in a window anywhere you want. Fairly inexpensive but wears well. Not the best for a home bathroom but saying it might work......
    Meadow Vista, CA
    2,108
    I use cultured marble in that situation. It's less expensive than corian and such and is easily fabicated and detailed around windows. How far do you have to go to get to a fabricator?
