Thread: paslode gas framing gun
09-10-2012, 10:05 PM #1
- 6,747
Have a Paslode gas framing nailer and seem to have a bit of a problem with the nails advaning. I do not know if the spring is not strong enough or what. On just about every nail strip I will get at least one missfire where the nail has simply not advanced to where it will shoot. But if I give the spring button a little push I can see the nails advance and it will fire after that.
Isolated case or not? solutions?
09-11-2012, 03:16 PM #2
- MIchigan
- 184
Re: paslode gas framing gun
Had this happen with mine. It was a tiny nub of construction adhesive on the nail track which some how got inside and then set up. My daughter found it after I had given up and used all the words I knew.
