Thread: Hinge cup holes
07-13-2012, 04:59 PM #1
- Dec 2005
- Michigan
- 6,508
Hinge cup holes
I'm looking for something we can use to do hinge cups in the field, very, very occasionally. And only like half a dozen at a time. Comes up once in a blue moon but would be nice to have a simple setup on hand when I need it.
We tried to use a Forstner bit today freehand and it didn't work. Without a drill press or fixture, it walks all over. The point isn't enough to stabilize it. What would work best? Forstner with a certain small template (which one?), router template, something else?
What has worked well for you?
07-13-2012, 05:04 PM #2
07-13-2012, 05:39 PM #3
- Jan 2009
- Danbury area of western CT
- 4,412
Re: Hinge cup holes
What he ^ said. ;-)
07-13-2012, 05:42 PM #4
- 5,569
Re: Hinge cup holes
There are lots of jigs out there. some very simple http://www.cabinetmart.com/Easy-Dril...3?currency=USD
and some very expensive http://www.cmtutensili.com/show_items.asp?pars=PJJ~~2 and a whole bunch in between.
I've never had to drill them onsite. I always do it in the shop with the drill press or a router.
07-13-2012, 06:01 PM #5
- portland, maine
- 708
Re: Hinge cup holes
I've used this jig a LOT, not perfect but it works well: http://www.rockler.com/product.cfm?p...8&site=ROCKLER.
07-13-2012, 06:16 PM #6
- Apr 2006
- 50
Re: Hinge cup holes
+1. You could also add a layer of sophistication by adding a fence to the ply some certain distance (like 6mm) from the edge of the hole to align your holes that distance from the edge of the door.
And cut your jig to length some certain distance from the hole to align the hole that distance from the top/bottom of the door.---Jerry
Try to learn from other people's mistakes---you'll never have time to make them all yourself
07-13-2012, 06:36 PM #7
- Oct 2005
- Hudson Valley area of N.Y.
- 576
Re: Hinge cup holes
Your best off getting a small bench top drill press. You can do them by hand like suggested above but if you have a thin door , like 5/8" thick you have to be Very Careful you don't go though but need to go deep enough for the hinge. No problem with a 3/4 thick door. The Forstner bits have a center point that is slightly extended beyond the cutting sides. Even with the drill press, it is nice to have a jig to space the hinge holes from the top and bottom and in from the edge.
Just my 2c
Bill T
07-13-2012, 07:37 PM #8
- Aug 2004
- new jersey
- 508
Re: Hinge cup holes
I use Blum Ecodrill, its idiot proof and quick.
http://www.amazon.com/Blum-Ecodrill-.../dp/B0006HFCNM
can also drill dowel holes for press in hinges
07-13-2012, 08:38 PM #9
- Dec 2005
- Michigan
- 6,508
Re: Hinge cup holes
Thanks guys. I shoulda thought of the hole in the ply.
Bob, the Blum gadget looks super, but at $300 not sure it's something I want to throw in the back of the truck "just in case". A Forstner bit and piece of ply, definitely.
07-13-2012, 09:09 PM #10
- Apr 2005
- Southern California
- 156
Re: Hinge cup holes
I bought this one at 1/2 the price of the blum. a friend has the blum and blum is better
http://www.sommerfeldtools.com/Somme...oductinfo/SHB/Steven
07-13-2012, 10:52 PM #11
- Feb 2008
- Northwest Indiana
- 5,578
Re: Hinge cup holes
I have the CMT that drills 3 holes at a time. Also a $300.00 tool.
I used the Rockler prior to getting the CMT, it works well and you can set the depth, something you will need to watch with the plywood method.
TomLast edited by tjbnwi; 07-13-2012 at 10:55 PM.
07-14-2012, 07:02 AM #12
- Aug 2004
- new jersey
- 508
Re: Hinge cup holes
My thought was the first time I drilled through the front of a door I could have paid for one or most of one with the money spent on a new door
07-14-2012, 09:23 AM #13
- sonoma ,calif
- 1,674
Re: Hinge cup holes
i have made several jigs successfully .one used a drill attachment that not only kept the drill aligned but limited the depth.but that one from blum would of been a better purchase . I keep making excusses not to purchase one .Sounds like alot but it would be inexpensive when I used it .
07-14-2012, 05:20 PM #14
- Nov 2006
- Arlington, Texas
- 293
Re: Hinge cup holes
I used this one for a long time till I set up my drill press with a fence.
http://woodworker.com/fullpres.asp?PARTNUM=951-640Last edited by Lamar Horton; 07-14-2012 at 05:34 PM.
Lamar
07-14-2012, 06:14 PM #15
- Sep 2005
- Washington, DC
- 4,662
Re: Hinge cup holes
Here's a pic (and the SU file) of a jig I designed and built...it should give you an idea of whether something like it would work for you. I made the jig with the router too.
