07-11-2012, 09:33 PM #1
- Dec 2009
- Sterling Heights, MI
- 4,409
Plumber's help needed. (it's not too interesting)
I have a question about the vent pipes that extend beyond the roof. In Austin, I was cited for not painting the pvc pipe which we never did in Michigan. Now, when I do a roof, I always paint the pipes and the pipe flashings because it looks good and because I believe that the paint acts as sunscreen for the pvc.
My question is: is this a IBC code, or a local code?
If it is a IBC 2006 code, can you tell me the code location or post the verbiage. If I can locate this verbiage, I can force the insurance companies to pay for the painting of the pipes. It's only $20.63 each but I'd rather put it in my pockets than leave it for the insurance companies. They are already stealing enough from their customers.
07-11-2012, 10:21 PM #2
- Feb 2008
- Northwest Indiana
- 5,578
Re: Plumber's help needed. (it's not too interesting)
I don't think it is an IBC code.
Check your state plumbing code. It may address the issue.
If it was a local AHJ requirement, you may find it on their web site. If so you should get paid.
07-11-2012, 10:31 PM #3
- Mar 2006
- Boise, Idaho
- 3,155
Could you get the the guy who "cited" you for the information you are requesting?
ParkWest Homes LLC
Working Man Online Store
Living Healthy
07-11-2012, 11:14 PM #4
- Martinez, California
- 14,201
I don't know about Texas, but any plastic pipe exposed to sunlight deteriorates rapidly:
Originally Posted by "2010 CPC" (IAPMO IS 9-2006)
07-11-2012, 11:35 PM #5
- Dec 2009
- 4,409
That's the code I'm looking for but I've got to fit it into the code for OKC, which is the 2006 IBC. I'll keep searching in that book for something that looks like your version.
07-11-2012, 11:36 PM #6
- Dec 2009
- 4,409
07-11-2012, 11:41 PM #7
- Dec 2005
- Michigan
- 6,508
Sorry Dick, but you're wrong. I've got a dozen pipes sticking out of the roof of my house, all Sch 40 white PVC, not painted. 20 yrs old. No deterioration whatsoever. I've seen some CPVC hot water pipes that changed color after a few years (darkened) in basements exposed to sunlight. They held pressure just fine. I investigated out of curiosity and found out that this can happen, but it doesn't affect the structural integrity of the material at all.
In Michigan I've never seen a painted vent pipe, so it's not IRC/IBC as far as I know.
07-12-2012, 01:29 AM #8
07-12-2012, 02:17 AM #9
- Jul 2005
- 3,238
The rubber gasket on the vent flashing is the only thing I've seen deteriorate. 10-12 years and their toast.
Isn't PVC pipe and PVC trim basically the same thing?~Kent~
Abraham Lincoln
07-12-2012, 06:04 AM #10
- Easten South Dakota
- 3,664
"I would remind you that extremism in defense of liberty is no vice. And let me remind you also, that moderation in the pursuit of justice is no virtue."
--Barry Goldwater AD 1964
07-12-2012, 06:16 AM #11
Custom Home Builder
- Houston & Washington Texas
- 11,382
Dick
Like most things, plastic pipe performs better in Texas than it does in California. What I don't like is (1) it is ugly seeing white plastic sticking out of your roof (2) the neoprene flashing is a rubberry type material that will fail. I've never used anything except lead flashing that will last longer and blends in with the typical weathered gray shingle."We are going to relentlessly chase perfection, knowing full well we will not catch it, because nothing is perfect. But we are going to relentlessly chase it, because in the process we will catch excellence. “
Vince Lombardi
Photos
Twitter
07-12-2012, 07:00 AM #12
- Dec 2005
- Michigan
- 6,508
07-12-2012, 09:34 AM #13
- Chicago
- 3,576
A similar question was addressed in the June 2012 issue of JLC magazine (p.18). According to the response from a licensed plumbing contractor in California, most plumbing codes require PVC pipe to be installed to manufacturers instructions and most manufacturers suggest applying water-based paint where exposed to UV light for prolonged periods.
Wood storm windows in Chicago
07-12-2012, 11:38 AM #14
- Dec 2009
- 4,409
Allan, are the lead pipe flashings smooth or crinkley when your guys are done?
I've had too many complaints about the lead flashings because there are "fingerprints on them" or "they look old; did you reuse the old ones" etc. I've even had customers insist that I remove the new lead flashings and put on the 3 n 1's like their neighbors!
Also, I have observed that the lead flashings crack at the top on a regular basis. I think maybe that is occurring when the roofer or plumber folds the lead in too tight: not leaving some expansion/contraction room above the top of the pipe.
Lastly, I don't want to handle any lead products because of the EPA laws.
With that said, I will install lead, after explaining all of the above and having the customer acknowledge that their new flashings will be all crinkley. We paint them all, no matter what style.
07-12-2012, 11:41 AM #15
- Dec 2009
- 4,409
