Thread: The thingamajig
06-12-2012, 12:57 PM #1
- NJ
- 361
The thingamajig
New scribing tool from Australia
http://vimeo.com/33005138
Always impressed by simplicity of design.
I'll wait for a FastCap version in the $30 range
06-12-2012, 02:42 PM #2
- Jul 2008
- 369
Re: The thingamajig
That's pretty cool! $75 is a bit steep, though.
06-12-2012, 03:36 PM #3
- Clifton, NJ
- 2,385
Re: The thingamajig
But you're scribing while the "thing" is riding on a area about 2" away from the actual contact point.
I'll stick with my General compass.SteveC
06-12-2012, 06:09 PM #4
- Jul 2005
- 3,238
Re: The thingamajig
~Kent~
Abraham Lincoln
06-12-2012, 07:57 PM #5
- Jan 2009
- Danbury area of western CT
- 4,409
Re: The thingamajig
here's the YouTube video, which loads way faster.
http://www.youtube.com/watch?v=IbN-EquR3vM
06-13-2012, 08:50 AM #6
- Mar 2012
- San Gabriel, CA
- 81
Re: The thingamajig
Seems like a good tool for cabinet installers. Its a spin on a marking gauge.
What I'd like to see is a scriber that would do a good job scribing crown moulding to things like rock or brick fireplace surrounds in situations where the client doesn't want returned corners.Crown Molding by Spectacular Trim
www.spectaculartrim.com
architectural woodworking | custom cabinetry | mantels
CSLB# 971338
06-13-2012, 09:58 AM #7
- Feb 2008
- Northwest Indiana
- 5,578
Re: The thingamajig
Maybe this log scribe will work for you;
http://www.traditionalwoodworker.com...FbEBQAod5RiGVw
06-13-2012, 07:11 PM #8
- Sep 2009
- Portland, Maine
- 1,197
Re: The thingamajig
I think it looks sweet. I like the idea of the crisp cut line versus a pencil line.
It certainly still comes down to user accuracy / skill when removing the material though.Portland Renovations, Inc.
www.portlandrenovations.com
06-17-2012, 06:56 AM #9
- Jul 2005
- 3,238
Re: The thingamajig
Paul, when I'm scribing into stone I use a regular general set of scribes that I bent the point side with needle nose pliers out. This helps in getting back into the nooks and crannies. The other key to successful scricing into stone is to carefully examine the stone and look for any points where the stone angles towards the wood behinds its face. I'll take a cold chisel and clean them up before scribing. That and keep those scribes at a 90 degree angle to the stone and a steep back cut.
~Kent~
Abraham Lincoln
06-20-2012, 08:17 PM #10
- Feb 2005
- Plymouth, Ma.
- 116
Re: The thingamajig
P1020742.JPGP1020743.JPGKent, does your scribe look like this ?
Bruce B.
If it takes me twice as long to build something, does that make it "Half Fast" ?
06-22-2012, 08:12 PM #11
- Apr 2007
- southeastern South Dakota
- 1,722
Re: The thingamajig
when I'm scribing on stone or other irregular surfaces, I take a 5 penny nail that I bent into an L shape, and tape it onto the pointer side of my scribe compass. When I'm done scribing the stone I simply cut the tape, and my compass is instantly back to normal.
Mark
06-23-2012, 11:21 AM #12
- Apr 2011
- Idaho
- 309
Re: The thingamajig
I really like that tool.....especially with laminate...leaving an edge that doesn't chip seems like a good idea.
Although you can't beat the Fastcap Accuscribe at only $18.00.
http://www.fastcap.com/estore/pc/vie...7&idcategory=0
09-22-2012, 08:50 PM #13
- Dec 2005
- Michigan
- 6,503
Re: The thingamajig
The Accuscribe one also rides flat on the surface and keeps 90 deg.
http://www.rockler.com/product.cfm?p...FelFMgodMQMAKw
