Page 1 of 4 123 ... LastLast
Results 1 to 15 of 48
    San Francisco
    698
    Default Min Tool Requirements
    I started making a list of tools I require assistants to have because I got tired of them showing up with a bucket of junk and using my tools. Tell me what you think, as a bare minimum. (oh yeah the list is in spanish too)
    All of the following tools are required every day for work. Tools are to be clearly labeled for ownership, of professional quality and in working order. All tools must be stored in a tool bag or 5 gallon bucket when not in use.
    Safety Glasses
    Ear protection
    Tool Belt
    2 Carpenter's Pencils
    25' Tape Measure (minimum)
    Hammer
    Cat's Paw or Nail Puller
    Speed Square
    Nippers or Dykes
    4 in 1 Screwdriver
    Chalk Line w/ blue Chalk
    Utility Knife
    Drywall Saw
    1" Chisel
    2' Level
    Nail Set/Punch
    Putty knife/painters tool
    Vise Grip Pliers
    6" Wrench
    Nothing simple is ever easy
    Apr 2012
    259
    Default Re: Min Tool Requirements
    not sure exactly what type of work you are doing but I have a couple that I would add.
    folding wood ruler
    torpedo level
    maybe a plumb bob although I do not use mine often I still get it out several times a year to double check things.
    plain string/string line for long walls
    Vaughn type Super bar
    one or two small spring clamp, maybe something that opens up to 2 or so inches for the occasional straight edge clamp system
    gloves
    kneepads
    I know some of them are only occasionally get used but if you do not have them you are going to need them or wish you did have them.
    Dec 2007
    glastonbury ct
    362
    My assistant has worked for me for five years and is like my little brother. The only tools he owns are my seconds and I wouldnt dare use those. We share all my tools of which he is proficient in using and he takes very good care of all my stuff, just like I taught him Im obviously very lucky. I would rather him using my great tools then using inferior ones bc at the end of the day its my name on the job. How much do guys make hourly to have all that stuff out your way? Eric
    May 2009
    Kent UK
    3,152
    Not trying to be picky, but a "handraulic" handsaw might be useful :)
    But the point you are making is clearly serious. Since ever I started work in the late 1970's the foreman carpenter always checked out the potential guy's toolbag.
    If he didn't have most of what you say, he didn't get "the start"
    Oh, and at the time pencils wern't necessary.......... a nail was good enough
    Limey Carpenter
    May 2009
    Kent UK
    3,152
    And the answer is NO, NO and NO again
    You do not get to use somebody else's tools
    That will slow TWO men down
    Limey Carpenter
    Apr 2011
    Wasilla, Alaska
    621
    Pretty good list. You almost described my standard tool bag setup to a T. Except I personally would replace the 2ft. level with a torpedo level, and replace the vise grips and wrench with channel locks. I also don't have the drywall saw in my standard setup, but probably should. All in all, its good. Too much more and you would be asking too much, much less, you'll be playing the part of their tool box.
    Michael
    Apr 2008
    468
    Depends on what type of work you do and I found some guys like to use one tool for a task while others would use a different tool for the same task. Basically if they ask to borrow anything you keep in your pouch more than twice the third time they need to buy their own.
    Darrel Hunter
    May 2009
    Kent UK
    3,152
    one is a mistake, twice is coincidence.......
    Limey Carpenter
    2,454
    Small flashlight
    Compass
    Cresent wrench
    Japanese pull saw/ flush trim saw
    I would change the 4in 1 scrmewdriver to an 8 in 1, lots of square drives now
    Combination square
    Apr 2008
    468
    Lunch money
    Darrel Hunter
    May 2009
    Kent UK
    3,152
    dhl, you've just made me hungry............. breakfast number one down the local caf at 10 o'clock
    double suasage, double egg, double bacon, black, tomatoes, mushrooms, chips and beans, don't forget ketchup and english mustard all washed down with a cup of tea
    prefferably how my irish grandmother made tea........... strong enough to tarmac roads with
    Limey Carpenter
    down the shore
    2,032
    Beezo-
    What do you use the folding wood ruler for?
    It's been decades since I touched one.
    492
    renovations and extensions?
    Dust masks and good work boots before ear protection and safety glasses.
    At least, they will use them.
    nice work boots ( even if paid by you) are a good return....
    Apr 2011
    Wasilla, Alaska
    621
    Definitely safety glasses before boots.
    Michael
    Apr 2012
    259
    I often find my self using it for things like cabinets and shelves that have to fit pretty tight. I also will use it for doing coil stock bending. Just easier for me to get an accurate measurement when one piece has about 3 or 4 bends in it. Being off the amount of play you have in the end of a retractable blade take can be enough to throw off the piece. I find I still am using both ways of measuring since I rarely have to unfold the one tape much more than once or twice since a lot of pieces are one inch bend then a 4 inch bend then another 3/4 bend with a hem. I use the Stanley for the longer lengths such as the long leg of the window but the details are often done with the folding ruller.
