Results 1 to 15 of 17
    Georgia
    1,826
    Default best glue for metal to wood?
    What type(s) work best for joining steel to wood?
    5,576
    Default Re: best glue for metal to wood?
    I have always used PL Premium or Liquid Nails. You could try Instant Grab. Not sure I would want to use a urethane without clamping well.
    Boise, Idaho
    558
    What specifically are you joining?
    Apr 2008
    476
    Yeah, that's a pretty vague question.
    Darrel Hunter
    5,913
    If you just want it to stick: epoxy, pl premium, silicone.
    If it's something technical i.e. has to withstand a certain amount of shear, torque or heat I will talk to my industrial Loctite supplier. I've used their stuff for for metal guide bushings to acrylic for drilling jigs and metal to wood flush door pulls. They make an adhesive for every conceivable application. http://www.henkelna.com/adhesives/in...sive-14972.htm
    http://www.henkelna.com/us/content_d...alBrochure.pdf
    May 2009
    Kent UK
    3,152
    charles. There are two answers.
    Polyurethane glue or sika EBT.
    If the joint is to be flexible use EBT, if not use polyurethane.
    If you go for polyurethane you have 2 options, a liquid format like gorilla or titebond (purple) or a gel format dispensed from a tube using a skeleton gun
    Limey Carpenter
    May 2009
    Kent UK
    3,152
    update
    Sika EBT is avaliable in half a dozen colours. If they don't suit you, you can overpaint it.
    Limey Carpenter
    Georgia
    1,826
    Quote Originally Posted by dlhunter View Post
    Sorry, it's for threaded rod going into wood cabinet pulls. Needs to withstand a little torque, not much.
    May 2009
    Kent UK
    3,152
    Gel or liquid version of polurethane glue, Skia EBT, and even silicone at a pinch. they all work in the situation you describe
    In all cases ensure the rod is pependicular to the knob/pull after the glue has set, tightish tollerances help
    Limey Carpenter
    5,576
    Quote Originally Posted by charles View Post
    5 minute epoxy.
    Why would someone be twisting the knobs, shouldn't they be pulling on them?
    May 2009
    Kent UK
    3,152
    tjb has added glue type 4 to the list.
    His post has reminded me that a 5th and 6th glue types should be added to the list (in low torque appications) superglue and "miterfix"
    Limey Carpenter
    Georgia
    1,826
    First we twist to install (other end of threaded rod secured by nut), then pulled ever after.
    5,576
    Use these and a screw;
    http://www.amazon.com/8-32-Press-Woo.../dp/B003R3GJD4
    These and a nut;
    http://www.boltdepot.com/Hanger_bolt...nish_8-32.aspx
    These into the wood knob;
    http://www.buildex.com.au/multi-use_selection.html
    Dec 2008
    Somerset, NJ
    749
    I've used Gorilla Glue with success. The 4X expansion might be a pain to deal with, though.
    "American political opportunities are heavily loaded against those who are simultaneously intelligent and honest" --Richard Dawkins
    Georgia
    1,826
    Tom, those are good but the materials are already on site. The reason for threaded rod is that we are securing 4" thick insulation to an attic hatch.
