Guys have done tile for years but still get frustrated by it at times. So a couple of questions.
For those of you that use tile spacers, do you have a brand you like better than others? I have been trying out the Tavey spacers whiich sit on top of the tile and can be used at corners or between tiles since one side is a single spacer and the other side is the cross spacer. My issue is their size. The seem to hide a lot of the tile and I have had a couple of times where I have found a tile that was a bit undersized to look out of alignment but I did not see it because of the size of the tile. If I was using the nylon cross that go in the grout line I think I would have seen it.
For small rooms like a powder room. How many of you do a complete dry layout or story pole system before you start? I often get frustrated with having to back out of the room but needing to reach around the door frame while trying to get the tiles all in alignment. I find that I am often at some sort of weird angle and sometimes having to put a hand on a recently set tile to reach another and then noticing that I have slid the tile out of position or squeezed all the thinset from under it. Plus with the small room I do not always have the perspective of a larger room where I can step back and see how the tiles are looking. There is usually only one way to look at the tile until it is dry and then it is too late. Had this happen recently where I set a tile that was out of the box but undersized by 1/8 inch and did not notice it from one direction. But sit down on the pot and you see it from that angle. Very frustrating.
And I have almost always had an issue where tile hits up against a wood threshold. Very hard to get the grout to not pop out over time. My guess is the wood and tile move differently and the grout pops out. Or maybe I need to leave a larger grout line? Or no grout line?
I know with some complaining about lack of activity on the forums I could have made 3 seperate posts but I am only one person......
