Results 1 to 15 of 22
    Jan 2006
    upstate NY
    1,560
    Default Sidewalk slopes too steep
    They guy that is doing my landscape has a good eye and does good work. But on the last project the sidewalks were a little too steep between three sets of stone stairs, as far as comfort and safety. Especially considering it would be common to have people walk on it after tossing back a couple. I don’t really have anyone else that can do the type of hardscape he is doing so I really just need to double check what he is doing before he does it.
    So I was wondering if anyone has a rule of thumb for what the steepest sidewalk would be that is safe and comfortable in a residential setting. Not from an ADA standpoint but from a practical standpoint.
    Apr 2008
    468
    Default Re: Sidewalk slopes too steep
    I've always tried to keep side walks as level as possible. Maybe 3/8" per foot and add steps when needed. But all of the work I did was new home construction so I could grade the property and set the house elevation wherever I needed. I think I would still do the same on a remodel though. You don't want your sidewalks feeling like a handicap ramp.
    Apr 2009
    midwestish
    6,361
    Quote Originally Posted by johnny watt View Post
    You could seek to apply and adapt Bergmann's rule to the problem. It does get cold up there doesn't it? How much more than 5% do you want to go? Any code like thingies that may govern whether it's a walk or ramp? Seems that would be the practical starting point, after that it's site conditions/limitations and budget.
    ~ Samuel Butler
    Jan 2006
    upstate NY
    1,560
    The idea here is to walk out of the back/front of the first floor and have a couple sitting/patio areas on the way down to the water/shore/dock. Maybe I am wrong but I think every riser you can eliminate and build into the sidewalk slopes helps overall.
    Apr 2008
    468
    It's kind of a owners preference I think. What do the neighbors have? Do they have the same senario? Could you access their walks to feel out what they have? Have the client walk something close to what you propose so they have a better feel for their options
    14,198
    Johnny:
    I assume you are referring to a complex without any public accommodations, but you reference to a water/shore/dock bothers me:
    Does the ADA cover private apartments and homes?
    The ADA does not cover strictly residential private apartments and homes. If, however, a place of public accommodation, such as a doctor’s office or day care center, is located in a private residence, those portions of the residence used for that purpose are subject to the ADA’s requirements. Similarly, the leasing office of an apartment building or apartment complex, as well as a model apartment or home used for sales purposes, is a place of public accommodation subject to the ADA’s requirements.¹
    If the water/shore/dock is open to public you better discretely block/ban public usage without it being obvious that you are doing so to avoid ADA.
    ¹ http://ago.mo.gov/faqs/Americans-wit...A.htm#header1e
    Jan 2006
    upstate NY
    1,560
    This is a private single family home.
    Typically the owner owns up to the water's edge, but occasionally they own under the water to a specific point. I am confident the ADA has no valid application here.
    Apr 2009
    midwestish
    6,361
    Steps are a nuisance, so is slipping on ice [slime/moss/leaves] that on a shallower slope would not have been an issue. Me I'd rather err on having an extra couple steps than something a bit over sloped, esp since it sounds like there are some already in place/needed. Otherwise surface depending, 15% assuming it's not going to dump one over the edge of the abyss, pounding home the last coffin nail, etc. and the users are not too old/infirm.
    ~ Samuel Butler
    There are some very steep sidewalks in Seattle and San Francisco... you might not want to traverse them if you're inebriated... http://www.seattle.gov/transportation/steepest.htm
    May 2009
    Kent UK
    3,152
    San Fransisco is steep.
    British steep.. is Porlock Hill In Devon 1:4 IE 25 percent. Engage your lowest gear or you WILL warp your brake discs and burn the pads out
    Porlock Hill leads to Clovelly where the main street is "break every bone in your body STEEP" Foot traffic only.
    Here is a photo http://en.wikipedia.org/wiki/File:Cl...arp.750pix.jpg
    Limey Carpenter
    Upstream
    9,835
    Note from my most recent set of commercial drawings:
    "A1.07 - NEW SIDEWALK: NEW 4" THICK CONCRETE SIDEWALK WITH #3'S AT 18" O.C. EACH WAY. SLOPE SIDEWALK AWAY FROM BUILDING TO DRAIN AT 1/4" PER FOOT. BROOM SWEEP CONCRETE SURFACE."
    5,563
    One of my first memories was living in Halifax NS looking out the dining room window at winos slipping and sliding on the icy hill with a cop at the top of the hill and the paddy wagon at the bottom waiting for them to slide to the bottom. We didn''t need TV, nintendo and internet purn. We had steep icy sidewalks, drunks and street prostitutes right outside the window to keep up entertained.
    If you have a grade at the back of your house you have to get from A to B somehow. If you as the builder or owner can get sued because the occupant can't keep the sidewalk free from ice or is too drunk or uncoordinated to navigate it then the lawyers have won and we may as well hang up our balls and stay home and knit.
    May 2009
    Kent UK
    3,152
    Dave K, here is an English pub crawl, to end all pub crawls
    The pub crawl in question even has a name "The "Micklegate run" (in York) 10 pubs in less than 1/4 mile.
    You start at the top of the hill at Micklegate Bar......... for Bar read medieval "city gate"
    http://en.wikipedia.org/wiki/File:Micklegate_Bar.jpg
    An English pint (at over 5% alcohol) in every bar? ....................... no wonder that on a friday and saturday night there were a rotating set of 3 paddy waggons
    One in transit to the cells.............. and two for "collection"
    Even if you drink English "session beer" (3.7 percent alcohol) 10 English pints in 4 hours is HARD GOING :(
    EDIT I was young once. Not any more
    Limey Carpenter
    Apr 2009
    midwestish
    6,361
    Here's one for you JW
    http://i.imgur.com/ArHEY.jpg
    ~ Samuel Butler
    11,274
    3 years as a bike messenger in Seattle- I know all of those streets. I find it interesting that E. John street isn't mentioned- I think there are 5 blocks in the 21%+ range; that was my morning commute in to work. Although I could cruise over to Madison if I wanted a longer, but less steep, route.
