Thread: winder stairs
04-03-2012, 09:51 PM #1
- Oct 2011
- 8
winder stairs
Hi guys. I have a set of stairs that have a 90 degree winder at the bottom, and a 90 degree at the top. There is a straight run of stairs directly bellow this set, making the support difficult. Limited drawings attached. I am having difficulty visualizing the inside connections for the upper winder section. I can not build a platform for the last "square step", and simply stack the winders on top of it because of head room limitations bellow. I have a similar scenario on the lower part, but that seems easier to me so far. Any input would be appreciated.
04-03-2012, 11:39 PM #2
- Dec 2009
- Sterling Heights, MI
- 4,409
Re: winder stairs
Your screwed.
The drawing is showing headroom at 6-6. Experience tells me that you should be striving for a minimum of 7-0 on the plans and you'll often lose 2-4 inches in reality. You're behind the eightball to start.
I'd be looking to shift that lower unit at least half a foot backwards. If possible, grab another foot and that will allow you some flexibility in how you hang the upper unit.
04-04-2012, 05:28 AM #3
- Oct 2005
- off the coast of new england
- 412
Re: winder stairs
call Horner mill works have john help you figure out how to proceed .He is very good
04-04-2012, 06:45 AM #4
- Branford, CT 06405
- 3,453
Re: winder stairs
As posted your headroom is inadequate. Also, in CT your design doesn't meet code for winders such that your 3" dimension at the inside needs to be 6" minimum, then min 9" at the 12" walk-line.
Kind of hard to fix later, but check your local code first to see if the IRC was amended, which is where the 6" rule is for CT.Take Care
04-04-2012, 07:34 AM #5
- Mar 2009
- northeast pa
- 163
Re: winder stairs
It looks like the wonder winder platform is built out of 2x4 and the face is 2x12 which would hang down and give you something decent to attach the strait run stringers to. You could carry the angle up after for Sheetrock. According to my math that leaves you with 6'91/4" without resetting calculator for 32nds. I like German stairs Gutentite
04-04-2012, 09:49 PM #6
- Dec 2009
- 4,409
Re: winder stairs
I agree James.
That set of plans is drawn by someone in lala land. On paper, every line can hold it's own weight, and the weight of the entire house!
04-13-2012, 06:37 PM #7
- Sep 2009
- Tacoma, WA
- 28
Re: winder stairs
Do the treads not need to be 10" min. in your area? They do here as well as 6'8" min. headroom.
04-17-2012, 07:52 AM #8
- Dec 2004
- Central New Jersey
- 778
Re: winder stairs
Hi
What was the final outcome on this project.
I would like to see how this problem was solved for future ref and to learn
Rich
04-17-2012, 09:07 PM #9
- Dec 2009
- 4,409
04-26-2012, 11:12 PM #10
- Lake Placid, NY
- 1,111
Re: winder stairs
Why is this a rough framing topic?
04-27-2012, 08:19 AM #11
- 3,453
Re: winder stairs
because it was posted in two forums by the OP
It does involve framing adjustments, though!Take Care
