Results 1 to 14 of 14
    6,508
    Default Load control module needed
    I need a box that allows me to control a 110V load from an external low-voltage switch or dry contacts. Basically a relay and 12 or 24V transformer in a box, preferably with a receptacle on it.
    Yes I can make this myself, but I need a clean looking assembly that's hopefully listed or at least sold as a manufactured unit. Can you help?
    Apr 2006
    151
    Default Re: Load control module needed
    This looks like it might work. I have not used this model, but I have used relays made by the same company.
    http://www.functionaldevices.com/lig...del=PWH24V300A
    6,508
    Thanks David. That's just a 24V transformer in a box. Would need to add a relay to it. Might work.
    Apr 2006
    151
    Well stink! The reason I posted a link to that page was because that site came up in a search for a relay that I use called a RIB. It stands for Relay In a Box. They are self contained, compact, and very handy. They just don't have a transformer built in. I thought the page I linked was one that did.
    I get them at a local HVAC wholesaler as none of the electrical supply houses in my area stock them.
    6,508
    Yes we use the RIBs as well. Very handy little buggers, you can attach them to any JB.
    On this job we would have preferred a box with everything inside, but might have to settle for the box you linked and put a RIB wart on the side of it. Thanks again.
    5,578
    I have this Honeywell controller on my boiler. 24 volt T-stat signal closes a line voltage relay.
    http://www.altheatsupply.com/zone-sw...ump-relay.html
    6,508
    Tom, that looks very much like what I need. Do you know how much current the relay can handle? I'm looking at about a 1/2hp pump. No specs, I'll have to search the Honeywell site.
    Apr 2006
    151
    dgbldr, just curious, what is it that you are working on if I may ask?
    5,578
    The specs are on this page, scroll down. 7.4FLA, 2000VA total max.
    6,508
    OK, I eventually found the exact thing I need:
    http://www.pexuniverse.com/honeywell...al-transformer
    Thanks Tom for pointing me in the Honeywell direction. Your zone control will also work just fine, but is more than I need, although apparently cheaper.
    David, I'm doing a prototype flood control system. Need to control a line operated pump from a pair of dry contacts (sensor or alarm output).
    5,578
    You're welcome. Happy to help.
    Apr 2006
    151
    Sounds cool. Glad you found what you needed.
    Yorba Linda, CA
    414
    The Honeywell looks like just the thing, but if you want something smaller at a lower cost you might look at Wattstopper power pack. The "B" series is rated at 1 HP. There are other series with additional relays, etc. They're designed to work with occupancy sensors but work just fine with a switch or a pair of dry contacts.
    www.wattstopper.com/getdoc/1253/PPBroch05.pdf
    Steve
    6,508
    Thanks Steve. That's even better. I'll bookmark that one.
