Thread: Paperstone countertop
03-12-2012, 01:39 PM #1
- Oct 2007
- Portland, Oregon
- 1,176
Has anybody here installed this material? Looking for feedback please.
http://www.thenaturalabode.com/green...countertop.htmLast edited by tomthetoolman40; 03-12-2012 at 01:40 PM. Reason: add link........duh
03-12-2012, 01:44 PM #2
- Portland, ME
- 6,274
Re: Paperstone countertop
We've used it several times. We're using Richlite more these days, but it's basically the same thing. It's tough to work, but you can use regular woodworking tools. I think it looks pretty cool - kind of like the synthetic slate of those old lab tables.
03-12-2012, 01:56 PM #3
- Mar 2006
- Seattle, WA
- 11,275
I've used it a couple times, and use Richlite regularly too. I found it easy to work with, although it is heavy. Use sharp tools. Hand planes don't work very well.
03-12-2012, 02:28 PM #4
03-12-2012, 03:03 PM #5
- Oct 2007
- Portland, Oregon
- 1,176
Thanks guys. How do you finish the front edge? Is this a solid material, or like plywood with layers?
03-12-2012, 03:39 PM #6
- Portland, ME
- 6,274
Seems to hold up fine. Can chip a little with an undermount - good place for a slightly bigger chamfer than on the edges if you can.
And Tom - it's sort of like plywood - it's got a top layer you need to take care of."anxiety tempered by hopelessness."
03-12-2012, 04:06 PM #7
- Mar 2006
- Seattle, WA
- 11,275
What it is: paper saturated with epoxy and compressed. It has some grain. It I fairly impervious to most things, but you really should resell edges around under mount sinks. I think it's better to think of as a marble or slate- it will patina over time; may look a little weird for a little bit, but will get a very cool patina after a time.
It's not granite or plastic.http://www.lavrans.com
03-12-2012, 06:37 PM #8
- Mar 2006
- Southern Maine
- 432
For those who have used it - how does it hold up to UV exposure? I've heard it is subject to fading.
Ben
03-12-2012, 06:53 PM #9
- Portland, ME
- 6,274
Ben - I kept a piece rolling around in the back of my truck over a winter to see how it would do - didn't seem to lighten enormously.
03-12-2012, 07:17 PM #10
- Sep 2009
- Portland, Maine
- 1,222
As I understand, and was told by our local supplier, the product is comprised of multiple layers of recycled paper bound (compressed) by nut resins thereby making it a green product, not epoxy. Under it's "Paperstone" name, it was manufactured in Washington State, not so green for us in the NE. Richlite (as I have been told), is made by one of the guys from that company but now in PA, a bit better for us up here.
It does work like wood and holds up pretty damn well. I made a vessel sink out of some scraps for my office bathroom and have not had an issue in two years. I'll test it for a while longer and then have the market on hippie sinks and charge accordingly!
As far as it's use for counter tops, not in my house. I prefer a local product like slate or concrete, or wood where it's appropriate.Portland Renovations, Inc.
www.portlandrenovations.com
03-12-2012, 07:18 PM #11
- Mar 2006
- Seattle, WA
- 11,275
It doesn't do a whole lot, but will fade a little bit.
03-12-2012, 07:22 PM #12
- Sep 2009
- Portland, Maine
- 1,222
03-12-2012, 07:28 PM #13
- Mar 2006
- Seattle, WA
- 11,275
03-12-2012, 07:30 PM #14
- Feb 2008
- Northwest Indiana
- 5,577
Seeing as it is a nut resin, what about those with nut allergies? Should they avoid the product?
03-12-2012, 07:41 PM #15
- Mar 2006
- Seattle, WA
- 11,275
I don't think so- it has been certified for use in labs & healthcare facilities. Or... It was.
