Results 1 to 6 of 6
Thread: stihl cut-off
    Jul 2004
    Southeastern Indiana
    202
    Default stihl cut-off
    Would anyone have an opinion about whether the stihl TS 420 A or the TS 700 is more suitable for cutting hard rock and concrete?
    Feb 2008
    Northwest Indiana
    5,577
    Default Re: stihl cut-off
    The 700 has the more powerful engine. It is also heavier, so position matters.
    The blade you choose is just as, if not more important, than the saw.
    Va.
    3,675
    I have 2 of the 420s. They cut concrete and block fine. Doubt I would want to handle the extra 5lbs. of the bigger one.
    Sep 2004
    Rimbey, AB, Canada
    333
    How much cutting and in what position. If cutting mostly on the ground then I think bigger is better as the job gets done quicker. If you will be cutting horizontally and holding the weight of the saw, then a big one gets heavy quickly and tends to bind.
    ____________
    Darren Dolman
    Jul 2004
    202
    I guess I'm leaning towards the bigger saw, Almost all the cuts will be laying down and below me. In general, I prefer running machinery comfortably below it limits when possible. It comes with a 14" diamond blade, Tom, as to the choice of blade what do you recommend?
    Feb 2008
    Northwest Indiana
    5,577
    Go through this site, it explains the various grits, segments, patterns. All designed for various natural and man made products.
    http://www.national-diamond.com/
