Results 1 to 12 of 12
    Emerald, PA
    185
    Default anyone have a Makita 18v cordless die grinder?
    Been looking at die grinders for awhile to replace a Dremel style tool that Ive been using to clean out rotted wood before I fill with epoxy repair compound. The Dremel works OK but is slow and underpowered. I had my eyes on a Makita GD0800 variable speed electric model, but recently saw that they also have an 18v model in the LXT line. It doesnt have variable speed , but Im assuming that it wont have the top speed and torque that the electric models have. I am leary about using a die grinder without variable speed for control and safety issues when working in tight spaces.. Just was curious if anyone had the 18v model?
    Upstream
    9,835
    Default Re: anyone have a Makita 18v cordless die grinder?
    My 18v arrived yesterday. I'll let you know.
    Emerald, PA
    185
    cool ..........let me know what you think of it. Just curious, are you using it for the same purpose?
    Sep 2009
    Ft Collins, CO
    389
    I have the M12 milwaukee rotary tool, and it is a better tool than the corded dremel. It is perfect for it's intended uses, but I too plan on the 18v makita for the heavier duty tasks.
    Can't wait to see whatcha think Mr. Poor
    Upstream
    9,835
    Quote Originally Posted by dale rex View Post
    No, mostly for grinding metal. But I can test drive it on some wood. Taking requests...
    Upstream
    9,835
    So which bits do you use to clean the rot out?
    Emerald, PA
    185
    Ive been using the Dremel brand 1/8" shank high speed steel cutters both cylindrical and cone shaped. They are kind of small, and dont last very long when hitting hidden nails, but fairly inexpensive @around $5 a pop so I usually carry 3 or 4 with me in my tool box.. When I get a die grinder, Im not sure which cutter to buy for wood.........there are carbide ball mills with structured teeth, but i think the carbide wouldnt do too well when hitting the hidden nails. There are also the Kutzall brand of burrs, that dont have structured teeth , which I think might do better against the hidden nails, but might clog easier too. Have to experiment with the different varieties once I get the new die grinder.
    Upstream
    9,835
    Alrighty then...similar to all Makita LX cordless tools I've used lately, the LXDG01 cordless die grinder is most definitely a solid and reliable workhorse. Tried it on a rotted tree stump, a maple cabinet filler, and a commercial brushed nickel latch plate using an assortment of carbide bits, and stick lubricant when necessary. Works like a charm. Every bit as good as a corded model. Unless you're into variable speed, which I'm not sure why that would be a factor. I prefer maximum speed while grinding. It's all about touch. And feel. And lack of emotion as you move on to the next target. Never mind.
    Full Disclosure: No animals were harmed during testing of this product and I paid for each and every danged tool in my arsenal.
    Emerald, PA
    185
    nice review Richie. I am leaning toward the cordless model for obvious reasons. Its always nicer to work on a 2nd floor window sill without cords dangling down to the ground. Plus I use mostly aluminum ladders and electric tools dont mix well with metal ladders. The variable speed isnt extremely important. I figured it would add a little more control when in tight spots. But like you said, the feel and touch is important. Thanks again!
    K.C. MO
    36
    I have used the plain rotozip spiral bit for wood rot. Seemed to work well.
    Emerald, PA
    185
    I had tried my Rotozip one time with a spiral bit and I snapped the bit off after a few minutes of use. The Rotozip just seemed a little too bulky to me and didnt have the thin long neck like a Dremel or a die grinder has.
    Emerald, PA
    185
    bought one and used it extensively on an exterior paint and repair job. I used a Kutzall bit from Woodcraft. I was really pleased with the power of the tool and the speed of wood removal. The Dremel I was using before was a toy in comparison. Definitely my go to tool for grinding out rot for epoxy repair. I give it 5 stars! Should have bought one sooner.
