Thread: Go-to tools
02-13-2012, 12:34 AM #1
- Feb 2008
- So Cal
- 158
Go-to tools
I'm just finishing a job where I had to add a false beam between two existing beams. It's hollow; a pull-down movie screen is hidden inside.
I bought a couple of tools especially for this one: a Multimaster, because the new beam intersected several molding bands into which I'm butting the square profile pieces and coping the more complex profiles. It's a great tool---one that I don't know how I did without all this time. The dreaded job of cutting-back baseboard for cabinet installation or new door casing will dog me no more. I don't know if it's true for anyone else, but I couldn't resist testing its limits. I think I can truly say "There are bold Multimaster blades and old Multimaster blades, but no old, bold Multimaster blades.
I also want to give a shout-out to Collins Tools for their "bunny planes". I can't even recall how many times these little beauties have shaved me out of a jam in situations where I would have had to pare with a chisel. I was working on a scaffold board in a situation where I couldn't risk dumping the contents of nail bags as I climbed around. Instead of climbing back down, I just slipped the little plane into my pocket, something I couldn't do with a block plane and didn't dare do with a chisel.
I'm just wondering what other tools that I had thought of as frivolous purchases I might be missing out on.
JW"Will work for work"
02-13-2012, 01:24 AM #2
- Jun 2005
- 1,179
Re: Go-to tools
Here's my list of (seemingly) overpriced (must have) tools.
Lamello biscuit joiner. Absolute perfect joints with such ease, I've trained a chimp to do it.
Lamello lipping planer. If you ever have to do any amount of hardwood edging this is a tremendous time saver.
Domino. Because the Lamello bisquit joiner doesn't go small enough.
Track Saw. I don't think the brand matters. It will change how you work.
23 gauge pinner. Never worry about shooting yourself with an brad nail again.
Multimaster. If for no other reason than cutting of shims. I like the bi-metal blades/E-cut. They cut forever.
Rali Block Plane. Because sometimes I am to lazy to sharpen the blades.
Laser Level. I like the PLS.
Laser Measure. Too fast and too accurate to not have.there is ALWAYS a better way waiting to be discovered-
yfc
02-13-2012, 07:28 AM #3
- Jul 2005
- 3,238
Re: Go-to tools
~Kent~
Abraham Lincoln
02-13-2012, 10:17 AM #4
- sonoma ,calif
- 1,668
Re: Go-to tools
well my little box truck is a big ticket item but relative to the price of it i had a positrac installed .small change compared to the price of van but this last week it has rained ,without it i would not of been able to get to the jobsight on some days and certainly not to the actual project .that locking rearend has saved me my a#$@ big several times .so important with the trailer behind .
Sawhelper -it was a big expense the day i bought it . With in two weeks of using the automatic stop and not having to pull my tape out for every measurement that price I paid seemed so much smaller.
trac saw has become so valuable .
things that come to mind today
02-13-2012, 10:34 AM #5
- May 2007
- San Gabriel, CA
- 408
Re: Go-to tools
hilti pd30 laser rangefinder (expensive but reliably accurate)
multimaster (and recyclable blades that are only $7 ea when you turn in the old one)
02-13-2012, 10:38 PM #6
- Apr 2009
- Bitterroot Valley,MT
- 108
Re: Go-to tools
Ottoman, thank you for throwing that little tidbit in about using the multimaster for cutting back shims. I hit myself the moment I read that, why didn't I ever think of that? you just made my life a little easier.
Josh
02-13-2012, 11:57 PM #7
- Jun 2005
- 1,179
Re: Go-to tools
Glad it helped. Hate cutting back shims with a knife or chisel. To me a MM is worth the cost if only for shims.
yfc
02-14-2012, 05:59 AM #8
- Nov 2006
- trenton, nj
- 1,032
Re: Go-to tools
I like the MM for sanding nail filler too.
Brad
02-14-2012, 02:59 PM #9
- Jan 2008
- Berwyn, PA
- 711
Re: Go-to tools
GPS- thought it was an extravagant purchase 3 years ago
Probably saved $900 in gas in that time by not getting lostJosh O.
"If people knew how hard I worked to achieve my mastery, it wouldn't seem so wonderful after all. "
- Michelangelo-
02-14-2012, 06:44 PM #10
- Aug 2010
- 283
Re: Go-to tools
ottoman
"23 gauge pinner. Never worry about shooting yourself with an brad nail again".
I don't think I understand this statement. Shooting yourself with a pin nail definitely hurts
02-14-2012, 07:01 PM #11
- Aug 2010
- 283
Re: Go-to tools
How about the new/old Yankee (German) screwdriver? No cord, no battery. I only have a couple of ancient models but I think these great old tools are generally be discarded in favor of various mufti-gigawatt units (with perpetual dead batteries)
02-14-2012, 07:02 PM #12
- Jun 2005
- 1,179
02-14-2012, 08:33 PM #13
- 5,561
Re: Go-to tools
I second that. I have my own and I inherited two from my dad. I used to use them all the time before cordless drills became popular. They are especially useful for door hardware. They're light to carry around in an apron and just about as fast as a cordless and in some cases a lot less awkward. I ground a bit holder to fit the chuck to make use of better bits in all the modern heads.
02-14-2012, 08:38 PM #14
- 6,738
Re: Go-to tools
one that gets used somewhere on every job is the 5 in 1 tool. I use it a lot for scraping stuff, prying off trim or at least starting to loosen it. Keep it sharp enough that I can do a somewhat of a chisel job in a pinch. I even use it to clean paint rollers on occasion.
Another is the famous Hyde flat pry bar, often called a bee keepers tool. Used on almost every job at one time or another.
02-14-2012, 08:39 PM #15
- Dec 2006
- Upstream
- 9,835
Re: Go-to tools
Forgot about the Yankees. I'm looking at my Yankee 41Y chrome push drill as I type. Still have all the original bits plus some packaged replacements.
