I have a project that will require to tile over the floor (only) of a Shower Pan.
The shower is made of separate pieces of Corian. The pan is Corain, The threshold is Corian. The three walls are Corian sheets. Bottom surface of shower is unsightly and chipped but solid. Ripout just will be too expensive and only the unsightly bottom surface is to be tiled. I plan to sand and thoroghly clean the surface first to get good anhesion. After laying the tile, I plan to grout with epoxy grout to help with water intrusion. The drain will have to be raised slightly to accomodate the tile thickness.
The real question/issue I need to resolve is what material to use as the adhesive to lay the tile.
My research so far shows that there isn't agreement about tiling over Corian. I am asking advice on method to keep the bottom joints of the shower water-tight and the best material/process to lay the tile.to the Corian surface. I have seen suggestions of Mastic, modified thinset, and epoxy adhesive.
Any advice or obvious flaws in my approach would be appreciated!
Comment
