Results 1 to 6 of 6
    Mar 2011
    Takoma Park, MD
    25
    Default New Design Values for Southern Yellow Pine
    The following article by our own Ted Cushman was recently published in Coastal Contractor:
    Southern Pine: What’s Next? ~
    The American Lumber Standards Committee (ALSC) held a meeting on Thursday, January 5, to hear feedback from lumber producers, users, and other affected parties regarding a proposal to reduce the key strength values of Southern Pine lumber.
    The Southern Pine Inspection Bureau (SPIB), tasked with third-party verification and lumber strength testing in the Southern Pine industry, has proposed a reduction of 25 to 30 percent in published values for deflection and ultimate strength for all grades and sizes of 2x dimension lumber in the Southern Pine market, after testing of hundreds of Number Two 2x4 specimens showed a significant decline in the strength of the 2x4 stock. If the published values for lumber engineering characteristics are revised downward, that will result in a reduction of allowable spans in official span tables for Southern Pine, which will affect builders, framers, and deck builders. Reduction in the strength values for 2x lumber would also have a major impact in the wood truss industry.
    In reaction to SPIB’s proposal, other voices in the industry are urging a slower and more carefully considered response to the new test values — saying that it’s too early to make a broad modification before other sizes and grades of Southern Pine have been comprehensively tested, that a revision of grading practices rather than a change in span tables might be a better way to adjust, and that time should be allowed to phase in any modifications so as not to disrupt projects already in the pipeline.
    The current, existing engineering values and span tables for Southern Pine were set back in the 1980s after an industry-wide “In-Grade” testing program, which involved at least six years of lumber testing in all sizes and grades, and another four years of industry discussion and negotiation about grade rules and engineering values. This time around, only one size and grade of Southern Pine has yet to undergo a comprehensive series of tests, and only a few months have passed since those test values were made public. But a full program of sampling and testing of other sizes and grades has now begun — not just for Southern Pine, but for other major wood species (including Western lumber such as Douglas Fir, and Eastern pine, spruce, and fir). The Board of Directors of the ALSC has the authority to adopt an immediate change to Southern Pine engineering values if it so chooses; but given the incomplete information on the table today and the far-reaching consequences of any sudden change, it appears more likely that the ALSC will wait to learn more about the nation’s lumber stock before adopting a comprehensive revision.
    _________________________________________
    The day after Ted's article was filed, Prosales Information Service reported "ALSC Approves Design Value Changes for Southern Pine 2x4s" http://www.prosalesmagazine.com/indu...icleID=1796181 The take-away from the article is that while ALSC has made a decision regarding 2x4s, methods for redefining design values for larger dimension SYP lumber are still under discussion.
    While the ProSales article examines the emerging issues related to these developments for lumber dealers and others in the industry, we'd like to know what builders and remodelers are thinking.
    *Are you following this story?
    *What values are you using for projects still on the drawing board?
    *Are you in contact with your truss suppliers on their response to the news?
    *Are you worried about your own liability in projects that include SYP lumber and if yes, what
    are you doing to protect yourself?
    Jan 2009
    Danbury area of western CT
    4,412
    Default Re: New Design Values for Southern Yellow Pine
    Makes sense with all the fast grown lumber these days. Thanks for the info
    Phil
    Calyfornia
    715
    Thanks for posting, This one will not effect me, (never see SP here and I cant use it for structural anyway, or Hem Fir for that matter) but frankly I'm surprised it has taken so long. I also think that if one species is reexamined others will follow.
    May 2010
    Peabody, MA
    135
    Thank you for posting. I was following the story a couple of months ago but it fell off my radar.
    I'm surprised that they made such a radical (in my opinion) change on such short notice.
    I will investigate further tomorrow with my supplier to get a feel for what may be in the pipeline.
    Great post!
    Ron
    May 2010
    Peabody, MA
    135
    Just tried to open the link to the Prosales story but the article has been removed. Must have stirred up quite a hornet's nest for it to have removed so quickly.
    Mar 2011
    Takoma Park, MD
    25
    Quote Originally Posted by R James S View Post
    The link to the ProSales article works now. Click on http://www.prosalesmagazine.com/indu...icleID=1796181.
    It was a technical problem, not a controversy-induced takedown.
Tags for this Thread
