Thread: Exterior stain seal
01-05-2012, 12:06 PM #1
- Jul 2011
- Nacogdoches Texas
- 89
Exterior stain seal
My normal gig is 8 hours north of where I am at now so I am at my wits end with a problem here. I am working so close to the border of Mexico I can throw a rock and hit it almost. It is very dry and arid here which is so much different than my home town.
I am working on a hunting lodge and I took over phase three. In the first two phases the stain that was spec'd was Sikkens. It lasted a year before it started peelling. These walls get 6-7 hours of direct sunlight. The ones that dont get as much the Sikkens is fine.
This phase they suggested using Man O War marine spar varnish. On phase three I have a wall that get sun all day long. 8 months later it is starting to peel. I would like to have a solution before phase 4 starts. The painter and painter vendor have said that the marine spar varnish is about as durable as I can get for down here.
Just wanted to see what you guys think or maybe get some ideas from arid climate pros.
01-05-2012, 01:09 PM #2
- Jul 2006
- Portland, OR
- 2,311
Re: Exterior stain seal
Sunlight doesn't usually cause peeling, especially if what you are using is indeed a stain . . . for the reason that there is no surface film to peel in a penetrating stain. What are the surfaces that are being coated? I suspect the materials were not arid-country dry before they were coated and that the coating was not sufficiently vapor permeable to let out the moisture being baked out from within.
01-05-2012, 01:26 PM #3
- down the shore
- 2,032
Which Sikkens product was used? They have various products for different applications. Is it actually peeling (so you can pull a layer off with your fingers), or is it just getting splotchy and worn looking from wear?
Have you spoken with someone from Sikkens?
My only experience with Man O War is on a railing - it's lasted 10+ years in the shade with a new coat every year.
If you go with a marine spar, there are better (and more expensive) ones on the market than Man O War (not to say it isn't good). You'd need to contact a marine supply. These finishes are designed for boat building.
Also, in my experience, any sort of varnish or penetrating oil will need constant maintenance in the conditions you describe. There may be a product out there I don't know about, but I'd expect to refinish something like that every few years at the max.Last edited by S.Joisey; 01-05-2012 at 01:44 PM.
01-05-2012, 01:27 PM #4
- Jul 2011
- Nacogdoches Texas
- 89
It is stain I am using but it is coated with marine spar varnish to seal it. The varnish is what is peeling and not the stain.
The Sikkens iirc (been a while since I have seen it used) is a mix of stain and sealer applied 2 or maybe three part.
The wood we are using is quarter sawn yellow pine and it was acclimated for 3 solid months before it was installed. Mainly becasue it was a special order item and I didnt want to have to wait for it.
Also,the reason I believe it is the sunlight is because it is only happening on the walls that get sun. The wood is stable and not warping and there are no knots at all in this house except in the framing. The wood being quarter sawn makes it much more stable and less likely to absorb moisture. IE, quarter sawn white oak will will hold whiskey "water tight" in a wooden barrel. I know pine isnt as good as white oak, but the rules still apply.
A picture would help but I have never posted one on JLC and dont know how. If you or someone else can help me there it may help with the problem.
01-05-2012, 01:29 PM #5
- Jul 2011
- Nacogdoches Texas
- 89
01-05-2012, 01:33 PM #6
- Jul 2011
- Nacogdoches Texas
- 89
Just went through my old emails and the Sikkens they used before was the Sikkens Cetol. It is two part according to that email. Never have used it myself but have seen it once or twice way back and I wasnt here when they did the other.
01-05-2012, 03:21 PM #7
- Jul 2006
- Portland, OR
- 2,311
OK, you have three things at work there - the wood, the stain, and the varnish, and the combination is affected by the sun. I suspect a bonding or chemical problem between the stain and the varnish. If the stain was oil or alkyd based it stays oily and/or water repellant generally until all the carrier is fully absorbed then evaporated. If varnish was put over relatively fresh stain the varnish probably never bonded well. Better varnish may not make any difference. One would be better off sticking with a single product line and finding a stain and a top coating that are recommended for use together. You may not find such a thing, because stains are not intended to be top coated.
IMHO, the real problem is the concept of putting a varnish over a stain in an exterior application
01-05-2012, 04:45 PM #8
- May 2010
- Peabody, MA
- 135
I don't know if it is feasible but my experience has been that stain/stain varnish is a very poor protectorant of exterior surfaces. All the stained red cedar shingled houses I see suffer from curling and cracking whereas painted shingles hold up beautifully. Try to talk them into some sort of paint they can live with.
Ron
01-05-2012, 05:28 PM #9
- Jul 2011
- Nacogdoches Texas
- 89
Yes, that is the 24 dollar question. I posed this to the archys as well as my paint sub way back when. On this job my painter had to do exactly 84 different samples and send them the 4 hours to Austin where his office is. It was a nightmare. The paint isnt the only thing I had trouble with them on picking either.
On 2800 sqaure foot hungting lodge I have had over 134 ASIs. For instance I have had a 121.3 ASI and others too.
On a 900 sqaure foot gun house there were 37 ASIs.
Total RFIs were only 46 for both so it wasnt my fault for that many.
So I really want to just tell them what they need instead of going through that again if possible.
My painter told them there would be an issue but they didnt listen. But it is my resposiblity to make it work even if they cant. I am at wits end on this.
Do you have any ideas or brands? I know Paint is not an option with the quarter sawn wood. It would null all the money the owner spent on it and it was a lot.
01-05-2012, 05:58 PM #10
- down the shore
- 2,032
Sounds right to me.
The spar will peel if not bonded properly.
Sikkens specs not to use any other product over it. I tend to think whatever spar you put over it will not hold.
I'd remove the old finish and start over.
Once you get the spar off, it might be easier to stay with Sikkens. I've not used Cetol, but you might be able to re-coat without stripping all the way to bare wood. If you switch products, you'll likely have to start with bare wood.
Just my experience, but I'd prefer a penetrating oil to a spar varnish for something like this. When the oil ages, it just looks a bit worn until you re-coat. A varnish can really look shabby - peel, let water underneath through pin holes, etc. Then when you put another coat on, you see the shabbiness under the top coat.
Since you are in a challenging situation, I'd contact the manufacturer and find out from them if their product is appropriate.
01-05-2012, 06:07 PM #11
- down the shore
- 2,032
To post pics:
Click "post reply" to start your post.
At the bottom of the page below "Additional Attachments" is a "manage attachments" button. Click it.
It takes you to a page where you can choose the files you want to download. Two pics per post.
01-05-2012, 06:46 PM #12
- Chicago
- 3,576
It's the sun acting on the varnish and causing it to peel. I've seen it before in full sun applications here in Chicago: I can't imagine the additional intensity that far South.
You need product with the maximum UV additives you can find. Water is not the problem, the sun is. In fact nothing may work under those conditions. It would be advisable to talk to the manufacturer of any product you are considering and get their advice beforehand. You may need to recoat every year or two regardless.
What you may need is a different concept. Something that wears off without the possibility of peeling. It sounds cheesy and low-tech, but maybe the waxy spray-on clear deck sealers, like Thompsons, might work, and plan on respraying every year."If you only have a hammer, all problems look like nails"
Wood storm windows in Chicago
01-05-2012, 06:47 PM #13
- Nov 2004
- Boston, MA
- 3,918
Sikkens isn't what is used to be. The low VOC regulations have really hurt the product as far as I am concerned. Back when is was the Cetol 123, stain, and two top coat system, it was pretty good. Now they have a hybrid product, Log and Siding or something like that. It is a low VOC product, the dealer told me to use Jap Dry in it to get it to dry.
I have a house with 5000 sf of exposed Doug fir decking (inverted) all done with Sikkens. because of the low VOC laws, I recommend you suggest paint to the architect.Wanted: Twinkies, Ho Ho's and Ding Dongs.
01-05-2012, 06:53 PM #14
- Jul 2011
- Nacogdoches Texas
- 89
01-05-2012, 07:33 PM #15
- down the shore
- 2,032
