Thread: Range hood exterior vent
12-16-2011, 07:11 AM #1
- Jan 2008
- 50
Anyone seen anything better than the cheap thin ones that come with your basic range exhaust fan/hood.
Replacing siding on a high end customer and wants something a little better.
Rectanglar vent about 3 x 10.
Seems someone should make one with a gasket that seals a little better. But then maybe with grease could get stuck close at times.
12-16-2011, 07:37 AM #2
- Northern Vermont
- 1,381
Re: Range hood exterior vent
Ray H.,
Here you go:
http://www.luxurymetals.com/range_hood_vents.html
12-16-2011, 08:30 AM #3
- May 2006
- Moultonborough NH
- 117
Another is the Broan model 639 (http://www.pexsupply.com/Broan-639-M...FQXd4Aodaxcflg).
I used that one in a down and out installation and was satisfied with it. I don't think any such vent cap with a flapper on it will be as tightly sealing as a motorized damper, but the Broan was much better than the cheap ones you refer to.
12-16-2011, 09:35 AM #4
- Portland, ME
- 6,274
For looks, Seiho makes some nice caps.
12-16-2011, 04:46 PM #5
- Aug 2005
- 569
Do you have a tin man in your area? They should be able to make you something nice out of whatever metal(copper, stainless, etc.) suits you.
12-18-2011, 07:17 PM #6
- Emerald, PA
- 185
I have ordered Broan vent caps online a couple times because I ran into the same problem as you did with only being able to find cheapo vents locally. The Broan vents are heavy metal with spring loaded dampers, very nice but cost a bit more than Depot vents.
