Results 1 to 8 of 8
    7,733
    Default hammer drill won't hammer
    Have a friend who has the Bosch Bulldog hammer drill. It no longer hammers for him. I am suspecting the switch since it seems to be a click into place switch and not an electric issue.It drills just fine but no hammer or chipping ability. Any idea if that is something a guy not used to fixing tools might be able to replace? Him not me. My vote was more of the drill is nearly 8 years old it might be time to get a new one and just keep this thing as a heavy duty drill.
    Thoughts.....
    5,576
    Default Re: hammer drill won't hammer
    If for some reason the bits do not seat completely, they will not hammer. The Bosch units we repaired for my fathers rental used a special grease in the hammer units. If the grease was low there would be no percussion. The piston acted on the grease which inturn acted on the anvil.
    Bergen County, NJ
    4,410
    I had my Bosch hammer do the same thing after a while. It's a bigger version than the Bulldog, but the repair was cheap and I was told it's really just a wear and tear item. It was a $600 tool, so putting $70 into it was a no brainer.
    I don't remember the exact problem but I do remember it was commonplace.
    Jan 2009
    Danbury area of western CT
    4,441
    I only used hammer drills for things like tapcon screws and such. Anything bigger reach for my SDS plus. IfI'm drilling rebar holes for tying a foundation I reach for the SDS Max. I have a Milwaukee hammerdrill that has been going strong for 12 years now.
    Phil
    5,576
    Phil,
    The Bulldog is a SDS hammer drill/chipper. Inline configuration.
    Jan 2009
    4,441
    Ahh! OK. I should have looked it up, sorry.;-)
    Phil
    Apr 2008
    SF Bay Area (East Bay)
    2,554
    I actually just had this happen with my Bosch 11247; there was a moment of concern as I pictured my morning's work not getting done (although the tool has given enough use I wasn't too bummed). No hammering in either hammer/drill mode or straight hammer mode. I blew out some crud in the collar and in the chuck, and greased it up good. It still took a few attempts at hammering with a regular chipping bit before it sprang back into action, but it's been fine since. I think it was crud in the chuck or collar.
    k
    7,733
    will be passing all the information along to the guy to try out. Will see if any of it works.
