Thread: Mirror Demo
05-24-2011, 06:51 PM #1
- Dec 2006
- Upstream
- 9,835
Mirror Demo
OK, brain trust. Demoing a master bathroom. Removed narrow vertical and under soffit sections of mirror without much effort and mostly intact, all attached with globs of silicone resulting in very minimal drywall damage. The challenge will be removing the 11' x 4' section above the backsplash and three 4' x 7' vertical panels along the opposite wall. What's your best, safest process for this type of mirror removal?
05-24-2011, 07:26 PM #2
- Oct 2006
- Greensboro, NC
- 1,384
Re: Mirror Demo
Have you considered your local - a few trucks glass shop ? Why risk you know what.....? That's what I'd do. They have suction cups, kevlar gloves, garments.
I'd price it out $400 but I believe it could be done in a 2 - 3 hr service call $275. They'll take it away. Glass and glass service is relatively inexpensive compared to other trades.Last edited by Happy Home; 05-24-2011 at 07:30 PM.
05-24-2011, 07:39 PM #3
Re: Mirror Demo
I have suction cups, so I'd go after that starting at one edge, one guy pulling carefully on the cup, the other guys sliding a flat bar behind and gently prying. Scoring it with a glass cutter into small sections (a couple of feet each) will help, and you can usually run the cut by prying directly behind where the cut starts.
05-24-2011, 07:48 PM #4
- Dec 2006
- Upstream
- 9,835
Re: Mirror Demo
Wild card - all mirrors have a 1/2" metal channel edge, also siliconed to the wall.
05-24-2011, 07:48 PM #5
- Feb 2008
- Northwest Indiana
- 5,578
Re: Mirror Demo
When I have to remove mirrors like this I cover them with Vicor or duct tape. Prevents shards flying if something goes wrong. Leave an area clear for the cups. Most have come off better than anticipated.
There is the BB gun and broom method, if that's the mood you're in!
TomLast edited by tjbnwi; 05-24-2011 at 07:51 PM.
05-24-2011, 07:55 PM #6
- Feb 2007
- Gloucester, MA
- 73
Re: Mirror Demo
i did a 20 by 8' wall last year and scored first then covered with contact paper , worked great and i didnt need to sub it out.
05-24-2011, 07:58 PM #7
- Portland, ME
- 6,274
Re: Mirror Demo
Yeah, I was thinking along R's lines - cover it with some kind of sticky sheet. Unless it would be easier to just run your rotozip along the outside edge and re-sheetrock.
05-24-2011, 08:18 PM #8
- May 2007
- On the coast, in the forest about 50 miles north of San Francisco
- 88
Re: Mirror Demo
If there is room at the top drop a piece of string behind the mirror, move it back and forth and cut the silicone. Works fine if you have the room.
George
05-24-2011, 08:22 PM #9
- Nov 2004
- Boston, MA
- 3,920
Re: Mirror Demo
Without a doubt I'd have solid tires on the Bobcat for that demo.
05-24-2011, 08:23 PM #10
- Dec 2006
- Upstream
- 9,835
05-24-2011, 08:29 PM #11
- Dec 2006
- Upstream
- 9,835
Re: Mirror Demo
05-24-2011, 08:30 PM #12
- Dec 2006
- Upstream
- 9,835
05-24-2011, 08:41 PM #13
- Omaha, NE
- 1,879
Re: Mirror Demo
Another vote for using some sticky tape. I always remove direct glaze glass from big windows I'm taking out (think arches and rounds) to lighten the load. If the glass starts to crack while cutting it free, then the sticky carpet protective tape (on both sides in the case of a thermal pane) is a trick to keep the glass from making a dangerous mess.
05-24-2011, 08:46 PM #14
- Dec 2006
- Upstream
- 9,835
05-24-2011, 09:44 PM #15
- Oct 2010
- Oak Forest, IL
- 132
Re: Mirror Demo
piano wire behind it and cut the adhesive
Steve
