Results 1 to 15 of 26
    Jul 2007
    Northern Jersey
    1,283
    Default Protecting chisels
    Any ideas other than a leather roll up to protect chisels from getting beat up in tool boxes? I usually buy them on the fly and sharpen them when I feel ambitious. After realizing how many I have around it think its time to treat them better after I sharpen them.
    Oct 2006
    Greensboro, NC
    1,586
    Default Re: Protecting chisels
    Got this tip on these forums a few years ago.
    Get lengths of various diameter braided pvc tubing at the box store and slip them over the chisel. Works great.
    Steve
    http://youtu.be/KZ_7br_3y54
    Jul 2007
    Northern Jersey
    1,283
    Braided PVC? Not sure what you mean Steve
    Nov 2005
    IL
    275
    Quote Originally Posted by Top Notch View Post
    vinyl tubing
    Jul 2007
    Northern Jersey
    1,283
    Geeze wasn't thinking, Thanks I like this idea
    7,876
    No, I think he means expandable braided sleeving.
    http://www.buyheatshrink.com/braided...d-sleeving.htm
    Oct 2006
    Greensboro, NC
    1,586
    Go to the plumbing section where the tubing is like what you use for a water level. Next to it is a stronger tubing that has a mesh within the wall. Its called braided pvc tubing. I keep them in a zipper bag.
    The guys already posted.....since I just got home I went to the truck got a pic for you.
    Steve
    1,024
    to resist rust
    I cold blued my chisels
    Beware of the man whose belly does not shake when he laughs
    Nov 2007
    Brantford, Ontario, Canada
    1,477
    Quote Originally Posted by phillip View Post
    Seems this is going to need explanation too. I got rust with warm... then FREEZE your butt off, then warm.. of this winter.
    David Tuttle
    1,024
    no comment
    7,888
    now I know I am a hack. I do not think I have ever really worried about my chisels at all.
    I keep them sharp but once they are ready to go I stick them back down into my tool bucket and away they go. I can cut just about anything I need to and I do not think of them as fine finsih tools. Mine are just like the stanely shown and for the cost of them I do not concern myself to much about keeping the ends protected.
    So. California
    89
    I use plastic chisel guards. I picked up a set at Rockler but I don't see them on their website. They look like these. http://www.amazon.com/Footprint-1602.../dp/B003Y3BMA2
    LeeValley also has a set. http://www.leevalley.com/us/wood/pag...22&cat=1,41504
    Nov 2007
    1,477
    no phillip my tools are rusting this year as the weather is bouncing all over the place. What is bluing? I know of a blue used by machinist is that to which you refer?
    David Tuttle
    1,024
    Quote Originally Posted by texastutt View Post
    By "cold blue" I mean the common touch-up bluing found down at our corner gunshop that is simply swabbed on and then rinsed off, usually with plain tap water, repeat 3-6 times oil wipe and coat with wax or oil
    Not 100% protection but it does resist rusting, wipe dry and oil or wax as needed
    Last edited by phillip; 03-02-2011 at 08:06 AM. Reason: was going to post about blue body parts, thus the no comment
    Branford, CT 06405
    3,677
    Depending on how you carry your chisels it could be as simple as a covered Tupperware container with a block of 2" rigid foam scrap to set the tips in. Gets a little loose....change the side used for the tips.
    Take Care
