Thread: Wanted: Tapco Brake Buddy
02-05-2011, 01:23 PM #1
- Sep 2006
- St. Catharines, ON Canada
- 542
I'm looking to replace my tapco brake buddy that was stolen with the rest of my tools a few weeks ago. If anyone has one they want to get rid of, preferably in excellent-new condition. Please PM or email me.
I figured I would ask here in case someone has one they don't use, instead of me buying one new.
thanks...scott
02-05-2011, 02:20 PM #2
- Jul 2004
- Western suburbs of Chicago
- 5,554
Re: Wanted: Tapco Brake Buddy
Check your PM, Scott.
Greg
02-05-2011, 03:43 PM #3
- Sep 2006
- 542
Just to clarify, this is the profile roller, not the cutter.
http://www.tapcotools.com/pages/acce...rake_buddy.php
Thanks...scott
02-05-2011, 03:49 PM #4
- Dec 2006
- Upstream
- 9,835
Any luck on locating any of your tools, Scott?
02-05-2011, 03:52 PM #5
- Sep 2006
- 542
Nope, got the truck and trailer back damaged and my brake. That's about it.
Thanks...scott
02-05-2011, 05:44 PM #6
- Oct 2010
- Oak Forest, IL
- 132
When my stuff was stolen a few months ago, I ended up buying a new one from industrialladder.com Going by memory it was about $285
Steve
02-05-2011, 06:56 PM #7
- 6,746
I am assuming since you are asking for one that you must use it for your work. I have yet to see them in use by anyone that I know of but them my experience is pretty limited. They work well and add a bit of detail that others cannot give I am guessing.
02-05-2011, 08:09 PM #8
- Oct 2007
- Southern California
- 2,184
Scott, if you don't mind us asking, what technique(s) did they use to get your truck and trailer?
PMP • ESEP • CISSP
02-06-2011, 12:57 AM #9
- Sep 2006
- 542
02-06-2011, 12:59 AM #10
- Sep 2006
- 542
02-06-2011, 08:16 AM #11
- 6,746
Those look nice. I may have seen those installed but just assumed that those were always factory ordered columns.
You mind me asking how long it takes to set up and run those? And is is done in 3 passes/one pass for each flute?
Seems like a good thing to be able to make your company a little different than others.
02-06-2011, 10:11 AM #12
- Sep 2006
- 542
You can buy premade ones I think, these are just made out of coil stock. I like this because I can do them whatever size/color I want. They take about 2 hours to make 2 of them to install. Most the porches I have done only have 2 posts. I charge $200-$250 installed per post. I don't seem to do alot of them, but then again I don't go out looking for that work either. People that see them, love them.
Each bead is a single pass. Once setup you run the 1st bead on each pc, then the 2nd, then the 3rd. This eliminates alot of setup and errors.
Here is another nice detail I like to do with it, see attached pic. These people just recently had a door installed by another contractor. They realized after he installed the door that he could not match this detail. So I get to cap their door for $150. No one around here has this tool.
scott
02-06-2011, 02:50 PM #13
- Oct 2008
- Essexville,Mi. Home of the best walleye fishing in the great lakes.
- 263
Is the fluted corner all one piece? Meaning you bent it square with one side open to install. And how did you fasten the metal?
02-06-2011, 02:53 PM #14
- Sep 2006
- 542
02-07-2011, 04:13 PM #15
- Jun 2006
- Michigan
- 626
I've got a Van Mark Brake and have the trim former they make for theirs. Has the standard brick mold profile, as well as one like shown in the above pics. Cool thing - also has a crown molding like die and roller - you can literally "roll" a crown moulding profile as part of a basic soffit or wall trim.
I probably shouldn't have even bought the darn thing - I don't even do much siding stuff, but after I got the brake, I "had" to have all the toys that went with it. Darn thing cost near $400-450 or so.
Last couple years or so have broken me of that habit. Well, sort of...
JT
