Results 1 to 15 of 28
    Jan 2011
    2
    Default 'fogged' double pane windows
    Newbie here, thought you guys might know something I could not find on the web.
    35 Year old insulated glass windows have become 'fogged' (actually etched)
    tried to clean them by heating, slitting open the seal, then cleaning the insides, with the intent to reseal with butyl or polysulfide.
    On attempting to clean, discovered that the class was actually etched ! Close inspection with magnification showed a surface with a pebbled appearance like a 1/10 scale basketball.
    Question: what mechanism causes the etching?
    Best found on the web so far was it could be an enzyme. The brand of the windows was Fentron (must be out of business, cannot find window maker by that name on net)
    Since they are etched, found some free glass on craigslist and got that and used existing spacers and butyl to repair windows.
    Mar 2010
    Great Falls, Montana
    374
    Default Re: 'fogged' double pane windows
    I would say it is time for some new windows and suggest you talk to your local glass shop on what might meet yor needs. Oh by the way this forum is for those that are in the trades and not homeowners. Good luck.
    Randy
    Des Moines, Iowa
    3,920
    Randy
    On the building science portion of the forums we have been a little more accommodating of this type of conversation.
    We have been able to address and advise on some problems that have educated the masses that choose to participate.
    Mark Parlee
    EDI Seminar Instructor
    Des Moines, Iowa
    3,920
    Sheder
    Pictures help a lot; remember a picture is worth a thousand words or it will at least get the request for more pictures.
    Most of the insulated glass from that long ago is next to worthless from the seals no longer able to seal and contamination of pollutants and any gas that was in the space is gone.
    It could be better to consider replacement than repair but you have to make that decision.
    Give us a first name and location so we know what climate we are dealing with.
    Mark Parlee
    6,306
    Quote Originally Posted by sheder View Post
    This is the only question he asked.
    Des Moines, Iowa
    3,920
    Dan
    You are correct.
    Defensive mode sure can come up quick sometimes.
    35 year old glass and not knowing what contaminates the glass was exposed could be a lot of guesswork.
    Mark Parlee
    Apr 2009
    midwestish
    7,600
    Don't forget to evacuate the unit and to add new desiccant. Glass could have a mineral build up and/or be physically etched. Mechanism would be blown seal adds moisture, temp causes condensation which causes surface deposits which build and can, given time, chemically 'etch'. Read up on static and dynamic aqueous corrosion [of glass].
    ~ Meriwether Lewis
    2,519
    Suckers only last about 25 years before the dessicant is all used up. And pulling them apart and putting them back together will accomplish nothing. You will have sealed moisture inside which will fog all over again. The etching may be a coating that was put on the glass originally. Time for new IGUs (insuated glass units)
    Jan 2011
    2
    What is 'evacuate' have to do with insulated glass.
    To ans. one query for details, am in Seattle area, all shade, mostly the windows on the south side went first, even though very little direct sun.
    Dessicant: have taken apart maybe 10 different brand old insulated glass back before alum scrap prices when high and you could pick them up free off craigslist, etc. NEVER saw any dessicant in ahy type of insulated glass.
    I have taken apart patio doors and cleaned them successfully (maybe were chemically treated like some car windows vs. thermal tempering?) as they were a simple condensate and not etched. Those have lasted over 25 years with polysulfide sealant and purged with dry nitrogen during sealing, even did a couple with my argon bottle for welding.
    FWIW - the chances of me contacting somebody to replace windows is probably 4 orders of magnitude lower than getting a correct answer, or 10,000 times greater than the intelligence of the person who suggested that <G>
    So, back to a corrolary of the original question:
    anybody know anything about chemistry of glass??
    Des Moines, Iowa
    3,920
    not entirely sure how to take this reply.
    I tried to stick up for you in my first post and you seem to be trying to bite the hand of friendship.
    please clarify
    The ones that we have dialoged and helped out in the past did not come back with a seemingly idiotic reply. NW is suggesting replacement as did I; this is based on your description of things and us trying to help you out.
    Mark Parlee
    Branford, CT 06405
    3,677
    Insulated glass used to mean an air space; it has no bearing on today's performance IGUs.
    Mark
    That is why I usually don't answer any post where the profile does not apply. When someone expects the dessicant to pour out like sand once the seal is opened tells me all I need to know!
    Take Care
    Apr 2009
    midwestish
    7,600
    Not a thing. Please purge that and any talk of desiccant from memory as they obviously have no use here.
    ~ Meriwether Lewis
    2,519
    sheder has burned his bridges as far as I'm concerned. Bye bye.
    15,299
    If I remember Fentron windows were a cheap aluminum window manufacturer in Oakland or San Leandro in the 50s or 60s, maybe it'll come back to me if I think about it, but I haven't heard of them for years. Many of those cheap aluminum window manufacturers tried to modify their frames to accept dual pane in the late 70s, they were a failure as the added weight destroyed the frames, I know I installed some of them and have had to replace them.
    ― Warren Buffett
    6,306
    They were probably cheap aluminum bridges anyway. At least the fire desiccated them.
