Results 1 to 15 of 21
    Jul 2005
    Near the Burgh, Pennsylvania
    3,327
    Default Solid Door Jambs vs. Split Jambs?
    I have a client who uses split jambs most of the time. I rarely use them and infact havn't used them in years. What's the advantage over solid jambs beyond helping with wonky walls? Are they easier to set and shim. I mean, I should know these answers but I don't, and I guess... I broke in on solids and just kept using them.
    Gary K did you cover splits in your Book? I'd like some input from the door guru...yes I'm talk'en bout you.
    ~Kent~
    Holly Springs, GA
    3,287
    Default Re: Solid Door Jambs vs. Split Jambs?
    I just used split jambs for the first time on my basement renovation, and I like them. They go in faster than standard jambs, and they help with walls that might be a little off on thickness. You've still got to get something solid behind the hinges if you want them to feel "solid" when you close them, but even a guy like me who doesn't hang doors every day got to the point of only taking around 15 minutes/door, and that's fully cased when it's done.
    Dec 2008
    Concord, CA
    1,271
    OK so what are BOTH these types of Jambs?
    I'm assuming they are called something different here in CA otherwise I am not familer with either one! LOL ;)
    Washington, DC
    4,725
    When I used to trim regularly, I had my time to install pre-hung, split jamb, "Colonist" doors down to 10minutes/door. That was after I was all set up, doors unpacked and placed next to their locations.
    I've set lots of both types, and I like split jambs better. They're faster for a few reasons.
    Just to be clear, I'm comparing pre-cased flat jambs to the split jambs.
    Those flat jamb doors come with one side pre-cased, and the other casing tacked to the casing that is already applied. So right off the bat, when you pull the tacked casings off the door, they aren't too stable, and the miters can loosen up pretty easily.
    Casings are glued and stapled to the jambs at the factory, so on flat jambs, only the pre-applied side is glued, so obviously you'll have to glue the other side if you want them both glued. So that adds more time.
    Shimming: Easier on split jambs because I slide 2 shims pointed toward each other behind the jamb, VERTICALLY. So no need to cut them. On a flat jamb they need to be cut to length so they'll be the correct thickness at the point where you need them to be behind the hinge.
    However, if the framing is nice and plumb, then this isn't really an issue, since I just slam the hinge side tight, and only shim the strike side. But then again, you gotta get that shim back behind the strike, which imo is harder to do when the jamb is wider.
    And of course the main reason (probably the reason they were invented in the first place) is it really slows you down when hanging a flat jamb on framing that's too wide.
    Washington, DC
    4,725
    Quote Originally Posted by archmolding View Post
    They are pre-hung, pre-cased, interior doors.
    Flat jambs have a standard jamb, 4 9/16" wide, with a separate door stop attached, usually stapled, and the hinge side of the jamb is the pre-cased side. Casing is stapled and glued, and has corrugated fasteners at the miters. Another casing set is tacked to the applied casing, with the profiles facing each other.
    A split jamb is a 2 piece jamb. The door stop is part of the jamb, and is incorporated into the hinge side. So the hinge side has a slot that receives the other half of the jamb. You install the first jamb half, then slip the other half into the slot. Both halves have casing already applied.
    15,418
    Quote Originally Posted by Jessie
    Jessie:
    In my 60 years in this business the only "split jambs" I've ever seen are hollow metal jambs, so don't go looking for them in wood.
    ― Warren Buffett
    Va.
    3,675
    Been using split jambs for 20 plus years, only way to go for production trim.
    Memphis, Tennessee
    2,763
    Quote Originally Posted by Andrew R. View Post
    25 yrs for me, and I agree completely on production trim. Only thing that can trick you is if you get a badly warped/bowed door and don't catch it (it's possible, just trust me :)
    Paul
    May 2007
    North Shore, MA
    259
    I like to shim at the very bottom of each leg- the carpet guys use their kickers against them and throw off reveals.
    If you do what you always did, you are going to get what you always got.
    Dec 2008
    Concord, CA
    1,271
    WOW OK Pre cased doors? that takes all the fun out of it...I have never seen those ever. I may have heard of them...but They don't even use those in the tracts out here...
    The only thing we will do in order to speed up the install is order all the mitered casing Pre cut from the door company. But even then we mostly do classical build ups on our doors plinth blocks, casing, & entablatures.
    I dont even think my suppliers can get these type of doors...I wouldnt want to put them in anyways, as I enjoy casing work.
    15,418
    Jesse:
    While I've never seen "split jambs" in our area, there was a time in the 60s that some door pre-hangers were installing metal clips behind the jambs to nail to the trimmers so you didn't have to use shims. Along with those clips they pre-assembled the casing for both sides with cardboard at the corners and spreaders at the bottom. That went away by the early 70s. I liked the metal clips, but shimmed at the butts anyway, they were fast to hang but too much play at the butts.
    ― Warren Buffett
    Bellbrook. Ohio
    1,751
    I have set and cased lots of doors over the years as a trim carpenter and only a few split jambs. I prefer to hang the door, cut my own casing and case it separately, its the only way to get a good tight miter that will stay tight.
    -Dan
    Jul 2005
    3,327
    Jesse, the builder gets his splits with out casing. He buys a wide mdf profile so we would use clams and hang the casing on site. So hey don't knock it until you try it. After they are hung you can't tell the difference.
    After all, aren't you the guy who nails his crown into drywall? In the "Burgh" we call the hit'en air and it doesn't fly round here.
    ~Kent~
    Dec 2008
    Manassas, Virginia
    48
    I would say that over 80% of the doors we hang are split-jamb.... I order them with whatever casing happens to be specified for the project and with whatever jamb width I need.
    With the prices most builders around here pay, they are a must. I guess we are all products of our environment... most of the work here is production type trim... been paying the bills for years.
    Roger
    http://www.mitrecontracting.com
    TOLERANCE is the virtue of a man without convictions
    -G.K. Chesterton
    Dec 2008
    Concord, CA
    1,271
    Kent,
    Whats the point of getting splits if they dont have the casing?? seems like alot more work..as you still have to put casing on. Is that not the reason for getting split Jambs?
    If the stop covers the seam I could see the adjustabilty you could have for all the drywall variations. That could be really cool.
    I'm not knocking the product, I don't know anything about it. I would try them if they were ever supplied. Like a lot of these "make it easy" products always have their place. it seems that these doors are used a lot in Production trim work or in the tracts..and that is just not what I do. Also it seems that they are just used more back east...
    http://www.thisoldhouse.com/toh/how-...148144,00.html
    Interesting concept...Reminds me of Split columns. Always a pain dealing with that seam.
    Oh far as the crown in the drywall..well I think we already got into that on another thread. Glad you still remember that trick!
