Results 1 to 10 of 10
    Dec 2008
    Milford, DE
    164
    Default Air-tightness and durability
    What happens when a modern air-tight building is abandoned for any significant time? Any minor source of moisture in the building accumulates without active ventilation/dehumidification.
    Some claim an air-tight shell with vapor permeable walls will allow the moisture to escape, but how much moisture can such a solution handle?
    Has anyone considered a passive ventilation system when the HVAC isn't powered? Perhaps normally-open powered dampers in some well-placed passive vents?
    Northern Vermont
    1,381
    Default Re: Air-tightness and durability
    MDR999,
    The fact that abandoned buildings tend to deteriorate quickly is nothing new.
    In Vermont, if you abandon a building for one week during the winter, every pipe in the building will burst. As soon as the thaw arrives in April, the building will be flooded.
    Jan 2009
    58
    And those pipes might not even freeze in a well insulated, air tight building in Vermont... Without people cooking and bathing inside that abandoned house you've removed major sources of interior moisture and humidity.
    Jesse Thompson
    Kaplan Thompson Architects
    http://www.kaplanthompson.com/
    6,274
    How about opening a window?
    Houston & Washington Texas
    11,382
    I'm sorry but that violates EPA rule 53.000365.
    Dec 2008
    Milford, DE
    164
    Funny, that didn't even cross my mind; though people may board up the windows to deter criminals.
    Dec 2008
    Milford, DE
    164
    Quote Originally Posted by Martin Holladay View Post
    Perhaps a frost protected shallow foundation would be more resilient? In this case passive ventilation wouldn't be a good idea.
    I rarely come across discussion of the building under such conditions. Being such a large investment, it would be prudent to make it a bit hardy, no?
    Boston, MA
    3,925
    Quote Originally Posted by Allan Edwards View Post
    And there are no Tax Incentives for opening windows.
    Sep 2009
    Portland, Maine
    1,199
    Quote Originally Posted by mrd999 View Post
    I did a super tight vacation cottage renovation for some Californians a few years ago...it's visited every two or three months with no issues. My though is that the basement windows we didn't replace help the non permeable top of the building. As a check, I requested that they let me know if it was "stuffy" when they came back for a visit....never a mention and I check it myself from time to time when I'm in the neighborhood. I'm certain that no water is getting in, and if they are not there making moisture like Jesse mentioned, should be okay.
    Portland Renovations, Inc.
    www.portlandrenovations.com
    Northern Vermont
    1,381
    Yes, I know that it is possible to build a superinsulated home with a low rate of air leakage, and that such a home is much less likely to freeze than the typical Vermont home.
    I just used that example of the typical Vermont home, because MRD999 seemed to think it was unusual for an abandoned building to deteriorate quickly.
    Every winter, Vermont plumbers are kept busy repairing frozen pipes -- and that's in occupied homes. Every spring, Vermont plumbers are kept busy replacing cracked toilets that were left without antifreeze in summer cabins.
    When it's -25 degrees F at night, and the daily high at 2:00 in the afternoon is 0 degrees F, and that weather lasts for a week, you need a very good house to keep the pipes from freezing -- assuming there isn't any heat.
