Results 1 to 8 of 8
    Jun 2010
    Concord NC
    1
    Default Ice and Water Shield Re-Roof
    Three years ago I re-roofed a low pitch kitchen roof and used GAF Ice and Water shield as underlayment as added protection. I am now adding an addition to this home and the owners want me to re-roof the kitchen again to match the shingle color of the new room. What do I need to do with the ice and water shield? Can it be reused? If not, how do I remove it now that it is bonded to the plywood?
    Thanks Tony
    portland, maine
    713
    Default Re: Ice and Water Shield Re-Roof
    It's not coming off now, Tony. It's part of the plywood. In North Carolina, I would probably run a single course along the eaves, valleys and cheek walls, and use another roofing underlayment elsewhere--such as tar paper or Rooftopguard.
    Feb 2007
    Lexington, KY
    53
    If it's a low enough pitch that the manufacturer's instructions were to cover the whole roof with I&WS, then you probably ought to add a full second layer. As Mike said, it's not coming off.
    2,532
    How low is low-pitch? Shingles may not be a compliant roofing even with I&W.
    Jan 2008
    100
    You just strip it and add a new layer of I&W on top of it. the old stuff is not coming off at all, and in a rare occasion may also bond to the shingles, if thats the case you will earn some blisters in ripping it. )
    RooferJim
    www.jbennetteroofing.com
    Sep 2008
    WI
    37
    i was told by i&w manufacture that u can only have 2 layers, then u need to remove the plywood and start over.
    good luck getting the shingles off the i&w. start early in the morn and hurry up before the sun hit it.
    Oct 2006
    Greensboro, NC
    1,609
    Quote Originally Posted by kubietime View Post
    good luck getting the shingles off the i&w. start early in the morrn and hurry up before the sun hit it.
    Got me thinking.....lol...maybe you could build a small sled with a block of dry ice in it and pull it around. This is what some folks on these forums recommend to remove floor tiles..
    Steve
    http://youtu.be/KZ_7br_3y54
    Jan 2008
    100
    You just man-up and rip it. )
