Results 1 to 6 of 6
    Default portable Miller welder 3500 for $1000
    Hi there,
    recently I saw the ad offering a portable Miller welder 3500 and a generator for $1000.
    The seller says it's manufactured a year ago and has been used very little. Sounds like bargain, but that makes me suspicious. What can I ask the seller about to make sure I won't get scammed?
    Btw, you can take a look at the welder uder tools and equipment
    369
    Default Re: portable Miller welder 3500 for $1000
    Do I smell something?
    Western suburbs of Chicago
    5,554
    Quote Originally Posted by rustbucket View Post
    Just the foul smell of fried Spam.
    Greg
    Jan 2009
    Danbury area of western CT
    4,416
    5,554
    Quote Originally Posted by philthegreek View Post
    Hope he's not wearing any of that stuff when he's frying Spam - I hear the grease splatter can be painful.
    Greg
    Mar 2009
    just relocated from N. VA to Doylestown, PA
    38
    It looks like a Blue Star 3500 Honda or a Blue Star 3500 Kolher .
    Honda 140 A at 25 V, 30% Duty Cycle, 100 A a 25 V, 60% Duty Cycle; 80 A at 25 V,
    100% Duty Cycle
    9 HP Honda Engine;
    Generator Power: 3,500 Watts;
    Output Power Range: 40 - 140 Amps
    So at 80 Amps you can weld continuously for for 10 minutes (100% duty cycle) before overheating , at 100 Amps you can weld continuously for 6 minutes (60% duty cycle) and must rest for 4 minutes, at 140 Amps you can weld continuously for 3 minutes (30%) duty cycle and rest for 7 minutes. And that 's all DC. Works best with 3/32 -5/32 in thick mild steel. It can also be used to TIG weld which I never did TIG but is pretty difficult and requires a shielding gas. If you have never TIG welded I recommend you take a class if you want to learn it. The work that this TIG welder is rated is non-critical in nature. Best rods for Stick welding (SMAW) are 6011, 6010 for tack welding, thin walled pipe work; 7018 for more structural work . 6010-11 are easy to strike arc with and the puddle sets fast. Lot's of spatter. 7018 has a higher tensile strength and produces nice looking welds (as does 7024) but the puddle stays molten longer and is more difficult to handle. Basically this is for farm and light maintainence repair as well as some light structural steel. And with the generator you can run several power tools. They start at about 2000 brand new.
    Link for the product specs.
    http://www.xedf.com/itw/products/eng...3500/index.htm
    Link for the manual
    http://www.millerwelds.com/om/o498f_mil.pdf
    Kolher probably is very similar to the Honda engine but is 8HP instead of 9HP
