Results 1 to 7 of 7
    May 2009
    Tampa, FL
    196
    Default drop in jacuzzi tub
    I've got a bath remodel I'm pricing out. I was called in for the vanity and towel cabinet, but got to talking with the client and she asked me for prices on the tile as well. There are a few things I'm not sure how to tackle.
    - There is a drop in jacuzzi tub which rests on the horizontal tile surrounding it. I'm assuming this thing will need to be completely removed to do the proper backer replacement and waterproofing, but perhaps someone has some other thoughts. I've really never seen the plumbing below these things so I'm not sure how complex they are.
    - There is a wall that separates the tub and the walk-in shower, part of the wall has glass block with tile all around it (both sides). The owner wants the block left - but I'm a little concerned it will need to be replaced, thinking that the chances of proper waterproofing being done in 80' when it was built are pretty slim.
    For the tile I think I will be bidding against a fairly low bidder, who didn't mention anything to the owner regarding waterproofing. I know this is a non stop topic around here, but is there any articles on this subject I could pass along to the owner.
    thanks for the thoughts...
    Black Hills - Custer, South Dakota
    227
    Default Re: drop in jacuzzi tub
    Of course access to supply/drain plumbing will be critical to removing the tub without damage. You might consider reference(s) to the current TCNA handbook that would apply to details of your project be shown to your client - and as always, when selling yourself and your work, emphasize the fact that you don't sell "cheap". It's all about doing it right - and spelling those qualities out up front. Good luck.
    If you can't fix it with a hammer - you have an electrical problem.
    Feb 2009
    50
    Heres a good article from Dave Gobis.
    http://www.tilemagonline.com/Article...00000000665428
    How well are you familar with these systems? If you need a recommendation for a good tile contractor in your area let me know.
    Jeremy
    www.buildingforward.net
    May 2009
    Tampa, FL
    196
    Jeremy,
    Thanks for that link, I'd discussed some of the issues with the HO, but thought it might be nice to pass along some published material as well.
    Is there any sensible alternatives to tile on the ceiling in shower stalls? Obviously in the tight space it is important to have the waterproofing wrap all around to block the steam and what not. I was thinking something along the lines of a skimable cement based product that would be paintable. IMO some of the showers become a little overwhelming with tile on all surfaces.
    Feb 2009
    50
    While there are alot of liquid waterproof membranes out there, im unaware of one that is cement based, and if there was, id be afraid it lacked flexibility. Look into Laticrete hydroban.
    Jeremy
    Meadow Vista, CA
    2,110
    Those tubs can lift out but pay attention to the cut out. I've had some that were very difficult to slip into the opening even when cut exactly to the template. I had to remove some interfering parts on one to get it in.
    Also the tub base may be adhered to the subfloor with leveling material.
    May 2009
    Tampa, FL
    196
    Jeremy, most likely I'd use wedi building panels for my backer/ waterproofing. i'm comfortable with the system and have a source with very reasonable pricing. its less labor intensive than some others - so it ends up as savings for the HO.
    that said with the ceiling I was curious about something I could skim over the wedi with, to make a finished surface. existing it is a tile ceiling, the ceiling is rather low, so to me I feel like I'm being swallowed up by tile and grout. the cement skim would be more of an aesthetic thing, obviously not a barrier...
    As for the tub, seems the best option would be to get a price from a plumber to pull the tub and re-install once the tiling is done? Is the top flange of the tub meant to rest on the horizontal tile ledge, or is the tile meant to butt to the flange? (TCNA didn't seem to have a guide for this)
