Thread: Seriously rusted threads
04-05-2010, 04:03 PM #1
04-05-2010, 04:30 PM #2
- mass.
- 401
Re: Seriously rusted threads
Heat , Oil , Shock (with a hammer,not electricity )
Repeat12 Hours is only 1/2 a day
04-05-2010, 04:40 PM #3
04-05-2010, 04:57 PM #4
- Jul 2004
- Western suburbs of Chicago
- 5,554
04-05-2010, 05:20 PM #5
- Dec 2006
- CA
- 1,900
PB Blaster works well
04-05-2010, 05:23 PM #6
- Nov 2006
- South Central N.H.
- 117
I have always had good results with this.
http://www.kanolabs.com/Dale
Perfect is close enough.
04-05-2010, 05:26 PM #7
- North East
- 470
Dave,
Head to an autoparts store as their is an entire new line of (new to me) products which are night and day to yesteryears liquid wrench, marvel mystery oil etc.. PB Blaster is excellent for use and others have PTFE (not sure what it is) though now that I'm looking at the can, I see it is a Liquid Wrench product.. however the formula kicks in quick.
Use with plenty of adequate air.. These will knock you back if you inhale the mist which does linger.Last edited by StephenS; 04-05-2010 at 05:33 PM.
04-05-2010, 05:45 PM #8
- Sep 2007
- Middletown, Ohio
- 765
For a moment I thought this might be about the Global Warming Thread and others similar to it.
Carry on...
04-05-2010, 05:54 PM #9
- May 2006
- NJ
- 5,832
Dave,
I've used PB Blaster, with some success. IT generally comes down to heating the outer nut with a torch, and spinning it loose with a large bar or wrench.
I agree that heat is the best offense.Chuck
04-05-2010, 06:50 PM #10
- Mar 2009
- Connecticut
- 28
I will have to recommend Kroil from kano labs as well. I use that quite often and it works well.
"Pray, hope and don't worry"
St. Pio of Pietrelcina
04-05-2010, 07:35 PM #11
- Jun 2005
- Northern Vermont
- 384
Oxy-acetylene torch. I've never met rusted nut or bolt that wouldn't come apart after heating it red hot with my magic "blue wrench".
- Rich
04-05-2010, 11:08 PM #12
- Jul 2004
- NOLA
- 3,696
04-06-2010, 12:24 AM #13
- Meadow Vista, CA
- 2,110
Don't get it so hot that you un-harden the steel. Use a chemical.
04-06-2010, 08:11 AM #14
- Jan 2009
- Danbury area of western CT
- 4,416
If you want to try something old fashioned, try soaking the offending screwjack in diesel oil. Set it in a bucket of the stuff and let it sit for a few days. Then whack it a few time with a "persuader" and use opposing wrenches. If you have to work too hard at it, it might just be worth scrap weight. If you get it freed up, I would suggest you remove the screw, drill an appropriate hole 1/2 way down the base threads, and install a zerk fitting for easy future lubrication.
04-07-2010, 08:35 PM #15
- Georgia
- 1,722
Evidently there was a study done by Machinist's Workshop magazine in their April 2007 issue. The story looked at the different penetrating oils to see which one did the best job of removing a rusted bolt by measuring the pounds of torque required to loosen the bolt once treated. If the study was scientifically accurate, it turns out a home brew works best!
Here's the summary of the test results:
Penetrating oil ..... Average load
None ...................... 516 pounds
WD-40 ................... 238 pounds
PB Blaster .............. 214 pounds
Liquid Wrench ...... 127 pounds
Kano Kroil ............. 106 pounds
ATF-Acetone mix....53 pounds
The ATF is an acronym for automatic transmission fluid. You can readily get acetone and ATF, so mix some yourself and see if you can get the same results.
