Results 1 to 15 of 19
    Default Raise My Garage Door Header
    I built my house 10 years ago and one of the mistakes I made was installing a 16 foot by 7 foot garage door. Now I want to raise the door 21 inches by adding another panel to my rollup door. The big job is raising the header 21 inches. My garage is 23 feet wide and when we installed the header we ran the header all the way across the width of the garage so the header is 23 feet long. It is going to be difficult to raise the entire 23 feet so I was thinking about cutting the header so that it would be 16 foot and 6 inches. (The header would be above the door only not spanning the entire width of the garage) I would have two trimmers under each end of the header and a 4" X 4" stud at the ends of the header going floor to ceiling. My ceiling height is 10 foot 3 inches. Do you see any problem with my plans?
    Long Island, NY
    213
    Default Re: Raise My Garage Door Header
    If you are doing this to your house, and not one of ours, why would any of us see a problem?... If you are asking if this is a good idea..... perhaps you should hire a contractor...
    581
    I guess the only question I would have is: Is the final result compliant with the prescriptive code?
    A "yes" would be good. Otherwise engineering would be required.
    North/Central FL
    784
    I would think for a 16' header you would need more than 6" for jacks...just sayin'.
    At this point I say, Thanks for nothing.
    Upstream
    10,019
    Well then, by golly at this point, you're welcome. For nothing.
    Richie Poor
    6,304
    And that's exactly what you paid, too!
    You guys should be comics.
    Quote Originally Posted by Unforgiven View Post
    I have no idea what you are talking about.
    Louisville, KY
    3,771
    We are check the funny papers
    Louisville Exteriors
    Professional Installers of:
    Quote Originally Posted by johnr9q@yahoo.com View Post
    In which case you're not qualified to do the job.
    trenton, nj
    1,032
    Which is why most people on here don't want to deal with HO questions.
    Check out this thread I think it might help. http://forums.jlconline.com/forums/s...ad.php?t=41060
    Brad
    Sorry, I didn't realize this forum was for professionals only. I have built (doing all the phases of construction) 4 houses over my 65 years of life but I am not a professional builder. I am a mechanical engineer. I guess I should know what a "jack" is but I don't. Maybe they are what I know as cripple studs?
    11,370
    John- yes, they are also known as cripples. A double cripple on either end gives you about 6" of bearing to support that header. Things seem a bit lean, but it really depends on construction. Truss roof or stick framed with a gable that's got to hold up a ridge beam that holds 1/2 the roof, etc. Likely might want more bearing, but might not need it. I can't say right now.
    581
    Being a professional engineer I guess you have a right to be here.
    Being a professional engineer you might understand the liability of giving assistance based on incomplete information.
    I would suggest you make up some sketches of what is in place and what you plan to do and see the local building inspector. Most of the guys here who are inspectors appear to be friendly.
