Thread: Rigid Foam on interior
02-20-2010, 10:49 AM #1
- Nov 2006
- Calyfornia
- 715
Have started doing some research in this area but it seems like one of those where the more you learn the more you, realize you don't know.
About to close in a remodel job in Northern CA (bay area). The house was poorly built and designed and needed lots of reinforcement. The upshot is between windows and framing on some walls I can insulate maybe 25% of the wall (tons of 4x12 beams). Considering using a thin (3/4) layer of foam on strategic walls but not sure if it's a good Idea in this climate zone.
The envelope is 1/2 cdx, Jumbo-tech, Cedar shingle. with Fiberglass batts in bays One of my concerns is trapping moisture, the others are about cost effectiveness. Any input appreciated.
Andy
02-20-2010, 12:35 PM #2
- Nov 2006
- trenton, nj
- 1,032
Re: Rigid Foam on interior
I have been concidering the same for my own home and would be interested to know if it has been tried before and with what level of success or failure. I too am concerned with the possibility of trapping moisture, but also like the idea of adding a good amount of R value while taking minimal sqft away from my rooms.
Brad
02-20-2010, 12:48 PM #3
- Martinez, California
- 14,201
Andy:
You are going to have to cover it with 5/8" Type X sheetrock, there are disposal problems, here we have to supply the AHJ with a waste disposal plan and disposing of foams is one of the hardest to comply with, I would also figure the cost of bringing in an air quality consultant or Industrial Hygienist to test the air in the home when you are done for your own legal protection. Do you have a Green Building Code in the area? It will be statewide on the frist of the year, this 14 Day Air Flushing period made it into the new state Green Code."But one also finds in the human heart a depraved taste for equality, which impels the weak to want to bring the strong down to their level, and which reduces men to preferring equality in servitude to inequality in freedom"
02-21-2010, 06:54 AM #4
- Northern Vermont
- 1,381
Andy,
It sounds like you are considering 3/4" XPS or poliso. Either product will work fine; plenty of New England builders do it all the time. Two options: screw the drywall through the foam, or install strapping between the drywall and foam if you are worried about squishiness.
Of course, 3/4" isn't much -- for better R-value, think about thicker foam.
You can safely ignore Dick's advice about disposal problems and IAQ problems.
02-21-2010, 11:23 AM #5
- Nov 2006
- Calyfornia
- 715
Dick,
Disposal is not a problem. For yrs now I can't get a final inspection untill I show receipts and proof that I disposed of all debris at a location that sorts and recycles a certain percentage of the material They charge more for foam but I suppose they have to They also charge mafia rates for old treated lumber but thats another thread.
The green building code here seems to change everyday and is often contradictory to code or common sense, and has no regard for realistic cost for HOs. Still waiting for everyone to get on the same book never mind the same page.
Martin,
Yes I was thinking of XPS with 5/8 right over the top, there's so much bloody wood in the walls I don't think there will be any squishy effect. Much of it will be in a recessed alcove off a cathedral ceiling very high up so no one will ever have their mitts on it anyway. That is also the main reason I was concerned with moisture, it's a likely collection point.
There is an ongoing effort to control ground moisture under the structure (30 degree plus slope) but letting the building have drying capabilities is a must. Very difficult to tell how much moisture is coming from the ground and how much is ambient because of no climate control all winter, still need to do more research on my specific zone.
Thanks for the input,
Andy
02-21-2010, 12:35 PM #6
- 14,201
Andy:
You have to realize that Martin is in New England, not Marin County California, with your involvement with the Audubon Society I'm sure you don't want styrofoam ending up in the Pacific Gyre, I don't know Marin County's rules, but here across the Bay:
Originally Posted by Waste Diversion
When the question is posed of what to do with packaging foams we are told to bag them up and reuse them since there is no vehicle presently available for recycling. I've had some real problems with Walnut Creek on this matter, I was told that the only thing I could do witth styrofoam waste on a construction job was to pack it up and ship it our of state. :Each year as much as 150,000 tons of plastic debris, most notably Styrofoam, wash up on the shores of Japan alone, Saido said. Vast expanses of waste, consisting mainly of plastic, float elsewhere in the oceans. The so-called Great Pacific Garbage Patch between California and Hawaii was twice the size of Texas and mainly plastic waste.4
As to IAQ, that is a huge issue now with areas that have adopted a Green Building Code, many new homes are sitting vacant down in Los Altos, on the home I'm working on down there I have retained Linda Kinkaid to check all materials before they are placed in the home.
Originally Posted by Contra Costa
By the time you install a whole home ventilation system (assuming this is a remodel and not a new home requiring it) cranked up to 1.0 ACH you will spending more to heat and cool the home than they ever did before.
Originally Posted by Sierra Club
BTW, driving home yesterday I was listening to Michael Finney the KGO consumer protection reporter, a lady called in saying that she moved from a 1969 home in San Jose with no insulation and a PG&E bill of $160 a month, to a much newer fully insulated home in Scotts Valley 250 square feet larger, her bill is averaging $750 a month in the new home. Smart meters have not been installed yet, but she was asking why new homes consume so much more energy than old homes? I don't know the detail's any more than what I've said, her newer home wasn't new enough to be covered by the Green Codes that have proved disastrous.
¹ http://wastediversion.org/files/mana...271/03fall.pdf
² http://www.co.contra-costa.ca.us/dep...tcreek-ord.pdf
³ http://lomaprieta.sierraclub.org/The...p?q=2010010201
4 http://www.eurekalert.org/pub_releas...-pio080309.php"But one also finds in the human heart a depraved taste for equality, which impels the weak to want to bring the strong down to their level, and which reduces men to preferring equality in servitude to inequality in freedom"
02-21-2010, 12:50 PM #7
- 14,201
Andy:
I just read your post after posting:
That's interesting, as far as I know they are still not taking it here, in fact it was just a few months ago that I read (or heard) that advice to keep it and reuse it as packing, since I receive shipping but never send it I'm a scofflaw and bury it in the middle of the garbage hoping they don't find it.
Originally Posted by Andy
You've also got to consider customer perception, I remember building a home for an attorney friend, when we started he said: "Dick, there are only two reasons I'll sue you building this home, 1) If you kill one of my oak trees, and 2) If I catch you putting one piece of plastic in my home."But one also finds in the human heart a depraved taste for equality, which impels the weak to want to bring the strong down to their level, and which reduces men to preferring equality in servitude to inequality in freedom"
02-21-2010, 01:43 PM #8
- Northern Vermont
- 1,381
Dick,
I have no problem with the concept that most homes require mechanical ventilation. So what else is new?
I just get tired of you bringing up this obvious subject (which most conscientious builders have known about for, oh, 15 or 20 years) every time anyone brings up the radical idea of insulating their walls.
02-21-2010, 02:25 PM #9
- 14,201
Martin:
Originally Posted by Martin
The problem is that the use of toxic materials is requiring mechanical ventilation to be cranked up so high that energy costs are higher than if the buildings were not sealed up, this is the 80s commercial office building "sick building syndrome", how can we forget so soon?
And I get tired of you constantly promoting insulation over more important concerns such as the health of occupants and their structural safety. Non-toxic insulation in itself isn't a problem, and as far as I've heard there in only one brand of fiberglass that is non-toxic, all other insulation appears toxic when tested (I'm sure this will improve now that it's a major issue). Sealing up buildings is a problem, especially when there is insulation in the walls to hold the moisture, sealing up buildings then pumping in exterior air to constantly condition it costs more in utility consumption than anything saved by sealing up the buildings could ever save. We have now cranked up the ASHRAE 62.2 mandated 0.35 ACH to 1.0 ACH, but that increase is resulting in higher energy consumption than an uninsulated building.
It now appears that "green" and "energy efficient" are mutually exclusive.Last edited by Dick Seibert; 02-21-2010 at 02:34 PM.
02-21-2010, 02:39 PM #10
- Northern Vermont
- 1,381
Dick,
"Toxic" means poisonous. Can you point to a single instance of human poisoning caused by fiberglass batts in walls?
02-21-2010, 06:41 PM #11
- 14,201
Martin:
Read some of Linda Kinkaid's articles, I've retained her to help me avoid formaldehyde in building products, apparently fiberglass is the main culprit, although all forms of engineered wood products are contributing, California has a program to eliminate formaldehyde in all building products over a period of time. Here is the time schedule for phasing formaldehydes out of wood products, I'm sure there is something similar for insulation products, at the present time all I am interested in is an insulation product that passes today so I can get certified toxic free when done, and she says she has that in one brand of fiberglass.
I understand that there is a push in the next code cycle to force contractors to obtain an AQ clearance before a final is issued on a building permit. We now have a 14-day flushing period in the statewide green code taking effect next January 1st, ths solution is to not build with toxics in the first place so they don't have to be flushed.
Originally Posted by Healthy Building Network
In addition, if you seal a wall up with fiberglass insulation in the wall it's a magnet for mold, water comes though all code allowable WRBs, and sealed mold grows inside the walls, if a contractor has mold he might just as well file bankruptcy, insurance no-longer covers mold and the remediation claims on the average home run around $700,000 around here. Building codes are going to have to change before anyone is safe building toxic homes, sealing them up, and pumping the toxics out, to say nothing of the added costs of running the ventilation fans and heating and cooling the whole outdoors. .
¹ http://www.healthybuilding.net/healt...50_summary.pdfLast edited by Dick Seibert; 02-21-2010 at 07:06 PM.
