Results 1 to 12 of 12
    May 2007
    San Gabriel, CA
    408
    Default installing a wood shop floor over concrete garage floor
    My back could use a break and I want the wood floor environment in my home shop so I'm preparing to install T&G plywood subfloor over the cold garage floor. Other than using a vapor barrier, I'm thinking of using 1x strips 16" on center to help keep the flooring flat and the edges butted against eachother. I don't want a lot of flex in the floor but a bit would help ease the strain on my back standing for long periods.
    Is there a better way to do this? Anyone added a floor like this in their shop?
    Feb 2009
    410
    Default Re: installing a wood shop floor over concrete garage floor
    I would use drycore http://www.dricore.com/en/eIndex.aspx Or maybe Paton http://www.systemplaton.com/flooring.html with T&G OSB on top. You will have to tapcon the osb down to keep it lined up and stable for you. Either one will keep a floor warmer and then use those interlocking rubber mats in the areas that you stand the most. Either way of doing it will give you a solid surface that you can still move machines around on.
    I am considering one of these options down the road.
    5,576
    dricore!!!!!!!!!!!!!!!!!!!!!!
    Tj
    Feb 2009
    410
    The platon would work out cheaper than dricore
    i think especially for a shop. but check out the pricing for yourself guys.
    5,576
    You may be correct if you are not putting 3/4" ply or OSB over the product. I see it does say you can float the a laminate floor over it.
    It does not list a hardwood install without a minimum 7/16 subfloor. I would use 3/4 and then the fasteners and labor (I did read it is for your shop) to install, not sure it is any cheaper.
    Also no heavy equipment without a subfloor.
    Can you tell I am a big fan of dricore, I hate carrying 4x8x3/4 sheets into a basement.
    Tj
    May 2007
    San Gabriel, CA
    408
    This is a detached garage-not a basement. I'd like to install the minimum to keep it from being a significant transition from the driveway but am hesitant to just run T&G edged plywood over a vapor barrier and screw it into the floor thinking it wouldnt' make much of a difference compared to the concrete floor.
    Jan 2009
    Danbury area of western CT
    4,447
    @ $6.00 + for 4 sf "tiles", dri-core is pretty rich. I just finished a basement and the price had gone way up since I first estimated the project, like 30%. The client was understandin and paid the difference, but I originally priced the roll down stuff and 3/4 t&g ply as a comparison to $4.39/ tile.
    phil
    Los Angeles, CA
    4,264
    Go for a sleeper system and just pour a ramp to the old driveway. This way you get the bounce you need, plus room to run electrical, dust removal ducting and maybe even some radiant heating to keep the feet nice and toasty.
    Oct 2007
    Southern California
    2,184
    Think I'd try some of that rubber flooring material first.
    PMP • ESEP • CISSP
    May 2007
    San Gabriel, CA
    408
    Quote Originally Posted by BeachBoy View Post
    Been there, done that. The floor goes in on Saturday.
    mays landing NJ
    141
    Good idea, I have done this for two customers over the years. I ripped PT 2x material into
    2x2's and installed them over 30lb felt. The first time I used 5/8" touchsanded t&g plywood for the floor. Block tile went over this by the homeowner.
    The second time I used 3/4" osb t&g and 1/4" underlayment plywood. A year or so later I installed Bruce flooring over this. The flooring was obtained for the taking by the homeowner,otherwise I think it would be a waste of money to put a laminate floor in a woodworking shop.
    mike
    9,252
    Quote Originally Posted by kwoodhands View Post
    mike
    Not to mention slicker than snot with a little saw dust on the floor.
