01-01-2010, 02:02 PM #1
- Anchorage, Alaska
- 716
Lead Safe classes available at the Builders Show in Las Vegas
The lead safe classes are available later this month at the Builders Show in Las Vegas. If you are coming and don't have classes available locally, this might be a way to get the certification out of the way.
If you are interested, you will need to take 2 classes at the Builders Show. One class is book, and one class is field. You need both to be certified. The book class is on Sunday the 17th from 9 am to 2 pm. The second class in the field, is listed with 3 different times that day and 2 times on Monday the 18th, so look on the list to see what works for you for that second part.
www.buildersshow.com
There are no other lead safe classes at the Builders Show than the ones I've listed.
