Results 1 to 6 of 6
    May 2009
    Kent UK
    3,152
    Default power ratings of power tools, amps or watts
    just trying to understand a bit more about the rating of power tools
    i'd probably never have asked the question if i hadnt bought an american skilsaw
    my 8 1/4 wormdrive is rated at 13amps (my guess is it is the power draw) 110v 60Hz
    all my other tools are rated in watts (input) and happen to be 240v 50Hz
    is there any real difference in using amps or wattage as a measurement ?
    why the difference ?
    Limey Carpenter
    Oct 2005
    Grand Rapids, MI
    62
    Default Re: power ratings of power tools, amps or watts
    Ohm's Law -
    Amps times Volts equals Watts
    Watts divided by Volts equals Amps
    Using algebra, if you have 2 of the 3 you can find the third. Your 13 amp saw @ 120 volts would be 13 x 120 = 1560 watts. If they gave you watts and volts, it would be 1560 divided by 120 = 13 amps.
    May 2009
    Kent UK
    3,152
    i remember ohms law from school, it was taught as V=IR
    i was under the impression that V = volts, I = Amps and R = Ohms
    like you say format in which ohms law it is learnt is immaterial because the unknown item can be calculated from the other two using algebra
    but where i am comming unstuck is that your calculation says that
    Watts (1560) = Amps (13) x Volts (120)
    the jump in understanding i am missing (all these years since school) is that your calculation, says that
    V stands for watts
    R stands for voltage
    Limey Carpenter
    2,196
    You guys got it all wrong
    This will clarify everything you need to know about watts and volts
    http://www.abbottandcostello.net/clips/watts.wav
    Nov 2009
    Broussard, LA
    16
    The Japanese often use wattage to specify the output of electric motors. It's easier to use if you're engineering an application involving it. On power tools, American manufacturers generally prefer specifying amperage and voltage.
    For power tools using AC/DC motors (DC machines with brushes and commutator), the wattage can be closely approximated by multiplying the amperage by the voltage. The amperage can be calculated by dividing the wattage by the voltage. It's not really important whether the tool's power is specified by amperage-voltage or by wattage. It's just a matter of manufacturer preference and industry standard.
    Keep in mind that these formulas don't apply to AC induction motors such as capacitor start or shade pole. Many table saws use capacitor start motors.
    Sherlock
    Des Moines, Iowa
    3,889
    The 13 Amp rating on the motor is not what it will draw under normal load but rather when it is being pushed a little hard typically through a rip. You can exceed this amperage draw if you really drag down the motor. this will heat up the breaker and trip it, or if you have too big of rated breaker will start to smoke the motor.
    Remember all things electric or electronic have smoke inside them and when you let it out you have ruined them:)
    I stands for current in amps
    E stands for electromotive force in volts sometimes V
    R is resistance in Ohms
    P is power in Watts
    I=E/R
    This link shows the power wheel and all its relationships
    http://www.etgiftstore.com/ohmslaw.asp
    Mark Parlee
    EDI Seminar Instructor
    Level one thermagrapher (Snell)
