11-07-2009, 08:24 AM #1
- Jul 2007
- Discovery Bay CA
- 1,123
AdvanTech® flooring --Beyond the Hype
The house we're building in Woodside California calls out 3/4" CDX for the subfloor. It looks like it's going to be a wet winter here in the SF BayArea and I don't want to use 3/4" CDX in the middle of the winter for subflooring because of the voids and knots in CDX that create soft and weak areas inside CDX plywood panels or delaminate. With 6 CMST staps dadoed into the top of the ¾” T&G CDX plywood subfloor, ¼”,the ¾” CDX plywood subfloor is really prone to delaminating and or developing soft spots.
I'm trying to convince the Structural engineer that AdvanTech® flooring does not have edge swelling like the rest of the OSB subflooring products.
Dumas-Residence-Woodside
Does anyone have any proof that AdvanTech subflooring edge swelling is less than the rest of the OSB products or CDX plywood? Besides the Hype / Proof from the AdvanTech website.
Sim
[NOTE: I belive that OSB is completely inferior to CDX for wall sheathing, but not for subfloor. ]Elucidation of the stuff is self evident
http://www.sbebuilders.com/tools
http://www.raftertools.com/
http://www.crownmoldingtools.com/
11-07-2009, 08:51 AM #2
- Portland, ME
- 6,274
Re: AdvanTech® flooring --Beyond the Hype
Not sure what constitutes proof but it's all we use for sub-floor. It's a great product, tough as hell, no edge swelling that I've ever seen, holds up to wet weather, and it's got no formaldehyde.
Why the hell does your SE get to make decisions on product? If he gives you a spec, I'm sure Advantech would meet it.
Feel free to contact me if I can help more."anxiety tempered by hopelessness."
11-07-2009, 09:11 AM #3
- Jul 2007
- Discovery Bay CA
- 1,123
Dan, maybe before and after pictures of Avantech subflooring with a couple of inches of standing rain water on the subflooring? Or in your case a couple inches of snow on the subflooring.
The SE in California is like a King. No one gets to build or use anything with their approval.
SimElucidation of the stuff is self evident
11-07-2009, 09:14 AM #4
Last house I built used 3/4" sturdi-floor and I bought 3 gallons of Moore long oil primer and painted the deck as soon as we finished laying it. Couple hours with a roller on a stick. Got great results that way with a frame that was rained on several times. Advantech is available here now and I might switch next time just to see what all the talk is about.
11-07-2009, 09:39 AM #5
- Port Orchard, WA
- 2,601
Sim,
We've used Advantech on a few houses and had great success with it. Right now it is about $23/sheet or so and LP Orange is about $15ish. We've had good success with the LP also. In my Picasa site, the "Bernies" job, got very very wet, but that floor did not swell at all. We ran dehumidifiers and when the inspector checked moisture content, we were nice and dry.
I know some guys in the past have posted about having a chunk of Advantech in a bucket of water and it not swelling. I meant to do that here, but just forgot.
It is a superior product to OSB or Ply. It is very dense and the floor feels more solid. It is very stiff.
If you are a first time user, you can get a rebate on it too, or maybe that is just the Zip. I'm not sure.
11-07-2009, 09:49 AM #6
- Portland, ME
- 6,274
No, Tim, you're right - the rebate is for all Huber products.
I'll see what I have for pix. But I like Tim's idea - cut a chunk so the edges are exposed, throw it in a bucket, then throw it thru the SE's window to show how well it keeps its strength."anxiety tempered by hopelessness."
11-07-2009, 09:55 AM #7
- Port Orchard, WA
- 2,601
Here in the Pacific NorthWet almost no one uses Ply. The last time we used it, about 12 years ago, on a roof, it delaminated within 2 days and we had to remove quite a few pieces.
With OSB, we don't have problems unless it is just sitting in the rain. On the walls, not a problem.
11-07-2009, 10:00 AM #8
- Jul 2004
- Desloge, MO
- 1,035
Dustin Wyatt
The first principle is that you must not fool yourself—and you are the easiest person to fool. - Richard Feynman
11-07-2009, 10:05 AM #9
- Apr 2009
- midwestish
- 6,363
Man, is Dick gonna be in a bad mood when he gets here.
Here where summer was well below "normal" temp and above in precip the projects I walked in Sept showed no adverse affects, nor did the better ply jobs for that matter. But I was seeing only dried in results and not always aware of total exposure duration/local condition.
11-07-2009, 10:29 AM #10
- Mar 2006
- Seattle, WA
- 11,274
That's funny- I've only used OSB on one small addition, and none of the houses I've been involved in building on have used OSB either. Especially on roofs- I've got some ply that's been sitting uncovered on a little shed out back for 3 years now without delaminating. There is a piece of OSB that I had on the back, but it fell apart a year ago even though it was a wall section.
Perhaps you got some of that 4 ply? ;-)http://www.lavrans.com
11-07-2009, 10:49 AM #11
Custom Home Builder
- Houston & Washington Texas
- 11,382
I don't use OSB but I did go kicking and screaming when my lumber yard convinced me to try AdvanTech. I learned it is a good product and can be rained on several times without problems.
I've never used anything less than 1-1/8" subfloor, it is pretty standard here on custom homes."We are going to relentlessly chase perfection, knowing full well we will not catch it, because nothing is perfect. But we are going to relentlessly chase it, because in the process we will catch excellence. “
Vince Lombardi
Photos
Twitter
11-07-2009, 12:50 PM #12
- Oct 2005
- off the coast of new england
- 412
I have been using advanTech for 5 years now and I would not go back to ply . I did a timber floor system with cypress ceiling boards last winter .I taped the seams where the Advantech went over the timber and cypress parts and the timber and cypress stayed perfect . we weathered several snow storms and several freeze thaw cycles and had no problems at all . I have not tried the LP Orange as it is not available locally. The Huber products that I have seen really work as well as they claim. I think we have used it on at least 30 houses in the past 5 years . Great product .
Sim I can email you some pics if you want.
Billy
11-07-2009, 12:52 PM #13
- Martinez, California
- 14,201
Sim:
Like Lavrans I've never had a problems with plywood in the rain, I recall back in 75 having one piece start to delaminate, I took it out and brought it back to the yard to exchange I was so mad, I think the only piece of wood I've ever exchanged.
What about asking the SE if he'll approve diagonal DF #2 1x8s instead of plywood? As I recall when plywood first showed up on the jobsites we continued to use 1x8s in the winter for fear of it coming apart, but they just had CD in those days, not CDX."But one also finds in the human heart a depraved taste for equality, which impels the weak to want to bring the strong down to their level, and which reduces men to preferring equality in servitude to inequality in freedom"
11-07-2009, 02:05 PM #14
- Va.
- 3,675
11-07-2009, 02:10 PM #15
Custom Home Builder
- 11,382
Vince Lombardi
Photos
Twitter
