Results 1 to 7 of 7
Thread: Azek vs fypon
    May 2009
    3
    Default Azek vs fypon
    Please explain as simply as possible the main differences between Azek and fypon for outdoor column trimming which will be hit by cold, rain, and winter snow.
    2,311
    Default Re: Azek vs fypon
    Few to none. Both cellular PVC.
    What, specifically, are you interested in knowing? Who are you and where are you? (fill in your profile)
    May 2009
    3
    One contractor estimated materials at double the cost using the Azek. rather than the Fypon...wondered if the Azek is a better material...
    May 2009
    3
    I'm an interior designer in Ohio...
    2,311
    OK, there's interior Fypon, which is urethane, and exterior Fypon which is PVC. I assume the guy priced the PVC stuff for the exterior application . . . or maybe not. If only one contractor had this bid phenomenon, he probably effed up his bidding and priced the interior stuff.
    BTW - everything I'm telling you is obtained on the manufacturer's websites. Suggest you continue your inquiry there, and with their respective technical departments.
    Mar 2009
    Rhode Island - Biggest Littlest State in the Union
    2
    AZEK Trim is now S4S (all four sides sealed) and is still the only trimboard with an ICC evaluation (International Code Council Report)....code approved for ground contact, termite resistance, fade resistance.......
    down the shore
    2,031
    Quote Originally Posted by Aardvark View Post
    This forum is for contractors, not sales. Read the guidelines!
