What material for 2ft-wide soffit and facia ?
  • What material for 2ft-wide soffit and facia ?
    Will need to be paintable and look (at least remotely) as wood.
    Was planning to use Miratec for both soffit and facia but they only make a maximum of 16" wide material.
    Should I just go with pre-primed cedar for soffit and Miratec for fascia ?
    Thanks in advance.
    Re: What material for 2ft-wide soffit and facia ?
    For the soffit just use 3/8 or 1/2 rough faced T1-11 / plywood as shown in the photo...
    FYI - I did not do the siding on this one - only added the soffit and fascia.
    “Racism is man's gravest threat to man - the maximum of hatred for a minimum of reason.”
    Abraham J. Heschel (Jewish theologian and philosopher, 1907-1972)
      t&g pine or cedar run it the long way,incorporate a vent strip or 2
        Hardie makes soffit in 24" widths I believe. You can also use 4x10 sheets and just rip them down the middle.
        My forum signature
          I've made up panels of 2 rips of 3/8" Cedar ply, with dark brown 2" wide continuous vent strip. Just attach the panels to each other via 2x4 blocks laid flat--make sure you lay them out so as to miss the rafters--and make up 8' long sections. You can pre-paint them, then nail up with SS trim nails with the 7/32"(I believe) head. You can even let the leading (outer-most) edge hang proud of the sub-fascia, then route a dado in your finished fascia, which the soffit panel fits into.
          1) Unconsciously Incompetent: He knows not, and knows not that he knows not. He is a fool. Shun him.
          2) Consciously Incompetent: He knows not, and knows that he knows not. He is simple. Teach him.
          3) Unconsciously Competent: He knows, and knows not that he knows. He is asleep. Wake him.
          4) Consciously Competent: He knows, and knows that he knows. He is wise. Follow him.
          May we all endeavor to progress from not knowing that we know not, to knowing that we know.
            ACX ply
            CCX plugged ply
            MDO
            I've even seen exterior grade sheetrock used.
            If one advances confidently in the direction of one's dreams,
            and endeavors to live the life which one has imagined,
            one will meet with a success unexpected in common hours
            ~Henry David Thoreau
              I second MDO. Or Fiber cement panels ripped to 2'.
                I have been using the SmartSide and love it.
                EDI Seminar Instructor
                Level one thermographer (Snell)
                  Oh Yeah, tell me more:)
                  Bill R
                  [URL="http://www.train2rebuild.com"]www.train2build.com[/URL]
                    For Soffit Bill
                    C'mon you are bait'n me
                    bbjhfnhss < whats this?
                      I was but it did not work.
                      OK, I'll bite, what is it?
                      bbjhfnhss
                      Fishin' Bill
                        every other word
                        bye b james h for n hello s side
                        this is the big one
                          every other word
                          this is the big one
                          Got it.
                          Welcome to the other side:)
                          Already There Bill R
                            No teasing you guys - tell us more.
                              Would MDO last in midwest-type environment ?
