Results 1 to 9 of 9
    New York
    471
    Default Base moulding size?
    I'm running base in a house that has 10' ceilings in the more "public" areas like the foyer,living room,dining,etc. It's a 1x8 with 1 3/8" base cap.It looks correct and proportioned in these areas.The "Private" area(bedrooms) is in a wing that is up 3 steps and has an 8' ceiling height,except the MBR that is vaulted.Some of these bedrooms are 12'x12',and the hallway is narrow.
    I'm thinking that the base might be a bit large in these areas,Should I consider transitioning down in size,say a 1x6 with base cap?
    (the transition itself would not be awkward as it would occur at the top of the steps)
    Big B.
    SE Wisconsin
    217
    Default Re: Base moulding size?
    Tough call because I think this is subjective. I would prefer the same size everywhere but it has been pointed out by architects that I dont know everything. Can you put a chunk of both and see which looks better?
    Is this design-build or can you get an answer from the owner or architect? I hate assuming one thing and having somebody over rule it and have to do it over again.
    brad
    Jun 2005
    Atlanta, Georgia
    175
    I would scale it down, Larger rooms=larger trim, smaller rooms=smaller trim.
    Robert Padgett
    Roswell, Georgia
    North/Central FL
    784
    Taller base in the formal areas does lend prominence to those spaces. I usually spec out smaller base in beds and baths.
    Jan 2008
    Chicago suburbs
    168
    Quote Originally Posted by bradcas View Post
    ... but it has been pointed out by architects that I dont know everything.
    brad
    LOL!
    My wife often make the same point to me.
    woodstock GA
    5,796
    i would go with a smaller base in those areas also. 1x6 total height would be fine.. and would look better on the 8 foot ceilings. and most of those rooms usually have stuff all along the walls anyway......
    Kreg
    www.builtinking.com
    Jun 2007
    Seattle
    935
    Just got my hands on a copy of "Get Your House Right" by Cusato & Pentreath. In it are listed, along with a lot of other things are base heights in relation to ceiling heights.
    11' ceiling= 1x8
    10' ceiling= 1x6 3/4
    8' ceiling= 5 1/2
    If you bat 1000 you're playing in the minor leagues.
    Warren Buffet
    New York
    471
    brad
    I have free reign on this one...all the glory all the blame.The more mock-ups I do, the more shrugs I get.
    Quote Originally Posted by Keith Mathewson View Post
    11' ceiling= 1x8
    8' ceiling= 5 1/2
    I just got my copy recently.Extremely interesting and helpful.I happen to think that 6 3/4" base looks small in a 10' ceiling area.The base in that area is a total of 9" and looks right,I agree it would look quite large in a 8' high room,I'll go smaller.
    Typical baseboard heat registers around here are about 9" high(not applicable on this job) and I would not say they look enormous or out of scale.
    Big B.
    CT
    285
    I go along with 1x6 and up to a full 6” base for 8’ ceilings. Just as important as the ceiling height is the size of the base in proportion to the casing. 2 1/4 casing gets 3 1/2 base and so on. I like 3 1/2 casing with 5 1/2 to 6” base and 4 1/2 casing for the large base as in one piece 1 x 8 or 1 x 8 with cap. That 1 3/8 cap on the 1 x 8 sounds small to me. The flat area under the cap needs to be in proportion to the cap and shoe, if used. I don’t use a 1/2 x 3/4 shoe on 1 x8 base but scale the shoe to fit the flat area and cap used. When using a taller base in just a few areas, we add a back band to the casing to keep everything looking good. It all has to work together imho.
